radio shack meter
radio shack meter
Anyone have any experience with a Radio Shack meter? How about it's accuracy? They have them for $35 and will do everything I need it for.
I have one I bought thru Radio Shack about 10 years ago. Still works fine for me. Although I`m sure their not made to have mucho watts going thru them. I havent seen the current ones they sell now, but I`m sure they do pretty much the same things still.
1. Got the power function with 3 ranges. 20 w 200 w & 2000 w...(maybe this thing can handle a little power?)
2.Shows SWR & can calibrate.
3. Avg & Pep modes.
About the accuracy? Couldnt tell ya. Never used any other meters to compare it to.
3. Avg & Pep modes.
Re: radio shack meter
The peak reading function is more realistic than a Dosy and the average reading function is quite generous. Not a good meter to use if you plan on running 800 watts peak or more because they will overheat and fail.Hayseed wrote: Anyone have any experience with a Radio Shack meter? How about it's accuracy? They have them for $35 and will do everything I need it for.
If you could possibly become serious about the CB radio hobby in the future a few dollars more can buy you a much better meter.
ask Jesse James he did the study for radio shack back when they came out and he could tell you best yes there are better meters but for the money they are great for swrs and you can leave them in line too yes the do have a little give in them but compared to a expensive bird meter which buy the way the radio shack meter is almost as accurate as the bird it is a great meter for under 40$ if you are not putting 500 watts or more of power thru them
how do you read it
I bought one and couldn't figure out how to read it. There are no numbers on the scales to read. I know that my radio puts out around 35 watts peak so I put the switch on the meter in the 200 range setting. I keyed up the radio and said AUDIO. The needle would swing up to about half way between the 200 and the 500 marks on the scale. What was this telling me ? How do you read that ?
jessejamesdallas Verified
It is a very good little meter. Made by Micronta. You will not find a better meter under $50...For as that go's, very few under $200 are any better, if at all!
Only draw-backs, is it does have a small meter, and no back-light. Meter also tends to read "Peak Watt's" a little on the High-Side, over 1500w's.
On my Suburban, the meter was showing I was peaking over the 2000w scale. (this is using a 8-pill box @ 14.5v's) When really, I'm closer to 1800w's...
But in the Radio Shacks meter's defense, allot of meters are not very accurate over 1000w's....
