CBRT has been
Title 95.407 On what channels may I operate?
Locked
Phaze91460
#51986
Post by Phaze91460 »
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.407]
[Page 529]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
               Subpart D_Citizens Band (CB) Radio Service
Sec. 95.407  (CB Rule 7) On what channels may I operate?
    (a) Your CB station may transmit only on the following channels
(frequencies):
                                                            Frequency
                        Channel                         (megahertz--MHz)
1.....................................................         26.965
2.....................................................         26.975
3.....................................................         26.985
4.....................................................         27.005
5.....................................................         27.015
6.....................................................         27.025
7.....................................................         27.035
8.....................................................         27.055
9.....................................................      \1\27.065
10....................................................         27.075
11....................................................         27.085
12....................................................         27.105
13....................................................         27.115
14....................................................         27.125
15....................................................         27.135
16....................................................         27.155
17....................................................         27.165
18....................................................         27.175
19....................................................         27.185
20....................................................         27.205
21....................................................         27.215
22....................................................         27.225
23....................................................         27.255
24....................................................         27.235
25....................................................         27.245
26....................................................         27.265
27....................................................         27.275
28....................................................         27.285
29....................................................         27.295
30....................................................         27.305
31....................................................         27.315
32....................................................         27.325
33....................................................         27.335
34....................................................         27.345
35....................................................         27.355
36....................................................         27.365
37....................................................         27.375
38....................................................         27.385
39....................................................         27.395
40....................................................         27.405
\1\ See paragraph (b) of this section.
    (b) Channel 9 may be used only for emergency communications or for
traveler assistance.
    (c) You must, at all times and on all channels, give priority to
emergency communication messages concerning the immediate safety of life
or the immediate protection of property.
    (d) You may use any channel for emergency communications or for
    (e) You must share each channel with other users.
    (f) The FCC will not assign any channel for the private or exclusive
use of any particular CB station or group of stations.
    (g) The FCC will not assign any channel for the private of exclusive
use of CB stations transmitting single sideband or AM.
Locked
