need some help on base
I have allways ran a mobile set up but considering a base at the house
I am thinking of buying a maco 5/8 and useing a spare galaxy 959 but there are some things I dont know??
1. I have some really picky neighbors...how do I stop interference on tv sets and other electronics on their end?
2. Can I mount the antenna to a peak of the house...or do I need a mast??
3. how far from trees do i need to be.....I found a gap between the trees right at the highest peak of the house!
4. last but not least....what kind of power supply and mic do i need....astatic or a rk 56??
5. thanks in advance for reply........
Re: need some help on base
Just my opinions and a bit of experience. Hope it helps a little.badwhiskey wrote:I have allways ran a mobile set up but considering a base at the house
A: Make sure your set up is well grounded, low-pass filter, antenna grounded, and get the antenna as high as possible. Those are a good start. Keep your modulation and wattage reasonable and under control to reduce splattering. If you are splattering on your own stuff in the house, then chances are good you are hitting the neighbors as well.
A: Height is might. The higher the better. Not knowing your layout, I'd say do the best you can for now, but be safe and get it up in the air.
A: Above them would be best. However, whatever is safe. I actually installed one of my Antrons (with ground plane kit) at the top of a 90' fir tree years ago. Worked great...provided I got the antenna above the tree. Some woods act like a sponge...for lack of better word. Theoretically wood is invisible to RF...but I know first hand close to a tree can affect it.
A: I've run mostly mobiles on the base. I actually prefer the flexibility of it. I use a 10amp power supply for most of my mobiles on the base, and 50 amp for the Cobra 200. I'm sure our sponsors here on the site can set you up with a decent quality one that will be reasonably priced. As far as the mic goes, it's preferrence. On the base I use my D104 Black Hawk...and hand held D104's in the mobiles.
![Wink ;)](./images/smilies/icon/wink.gif)
I apologize in advance, but, with tongue in cheek, I reply.....
1. Tell the neighbors to move. In my old case, I was the first one in the neighborhood. No one asked them to move close to me. Now I'm outside the big city, so it really doesn't matter. And before, I couldn't have cared less if I came over their toaster or their kids' fillings.
2. Peak is good, mast might be better, whatever is highest.
3. Trees do have an effect on your signal. If they contact part of your 50' yagi boom length, cut 'em down. If you don't like chain saws, get a big amp and RF'em down.
4. 220V, 200A service (for the big amp). Mics: D-104 or Turner +3 are good choices. If you think you need a noise cancelling mic, 636 is good, RK56 is good if you need a deeper tone, and check out the SkyThumper 65 from Sparky's on this site, good mic, good price.
Again, j/k with some of my replies.........![Cool 8)](./images/smilies/icon_cool.gif)
