CBRT has been
voices in amp
pardeville
Handle: New Guy
Real Name: John Johnson
voices in amp
#412413
Post by pardeville »
i just got my first amp its a texas star 667v. i have it all setup when I speak I can hear my voice it the amplifier. Is this a normal thing? a friend of mine has one as well but he does not hear his voice coming out of his. its like the electronics on the inside are echoing what I say. Is there anything I can do to make this stop? it just does not seem normal
Bozo
Owner
Owner
Handle: Bozo The Clown
Real Name: James
Antenna: Monkey Made MM9
Radio: General Lee Radio
Re: voices in amp
#412414
Post by Bozo »
@pardeville
Yes, it's normal to hear your voice through the amplifier when it's in use, especially when the amplifier is on and you're transmitting. The feedback you're hearing is likely caused by the microphone picking up the sound from your speakers, or it could be due to the amplifier being set to a higher gain.
Here are a few things you can try to stop the echoing or feedback:
  • Adjust the Mic Gain: Lowering the mic gain can help reduce sensitivity, meaning the mic won't pick up as much ambient noise (including the amplified sound of your own voice).
  • Adjust the Speaker Volume: Check that your speaker volume isn’t too high, as this can cause the mic to pick up the sound and create feedback.
  • Use a Noise Filter: Some people use a noise filter between the mic and the amplifier to reduce feedback and prevent the echoing sound.
  • Mic and Speaker Placement: Try adjusting the positions of your mic and speaker so they’re not too close together. This helps prevent the mic from picking up the sound that’s being amplified.
  • Check for Echo/Reverb Settings: If your amp has a built-in reverb or echo effect, make sure it’s turned off, as this could be contributing to the echo you’re hearing.
This should be able to reduce or eliminate the feedback you’re hearing.
Donate here
