CBRT has been
Pc78ltx. New
Otishawk15
Handle: Hawk
Real Name: Mik’e
Pc78ltx. New
#410505
Post by Otishawk15 »
How can we be of assistance to you? Well I’m in need of a on/ off switch for this new radio. Neighbor stupid cat stepped on the circuit board and broke it into. I know it new so I might be in a mess. I used a 5 pin pot on / off but they’re 6 wires. Where’s #6 go, maybe ground? Oh and thanks for the add. I’m an old road dog with a couple a million miles on me. Oh and one more thing ,,, I need ideas on how to skin a CAT⁉️‼️👋🤠
FYI: This post will be viewable to other members on the Forum, and so if you want to send a direct message to admin please go to contactadmin
Bozo
Owner
Owner
Handle: Bozo The Clown
Real Name: James
Antenna: Monkey Made MM9
Radio: General Lee Radio
Post by Bozo »
Hey there @Otishawk15 ! 🤣👋
So, like, I totally get your potentiometer quest! 🕺 Here's the lowdown:
1. Plug one end of the resistance thingy (usually the middle pin) into your radio's power input. 📻🔌
2. Stick the other end of the resistance thingy (opposite the middle pin) into the happy side of your power source (like the radio's positive power dealio). 🌞🔋
3. Hook up the last pin of the resistance thingy to ground (usually where your radio's feet touch the Earth, or a common chill ground spot). 🌍🤝
4. Now, for the switchy stuff:
5. One of those extra pins from the pot is like the cool common terminal (COM). 🤝🔵
6. The second extra pin is the NO (normally open) terminal, like it's usually chill and open for business. 🚪🆗
7. The third extra pin is the NC (normally closed) terminal, but we don't need that for this party. 🚫❌
8. To rock it as an on/off switch, connect the COM terminal to the happy side of your power source (same as step 2, like they're BFFs). 🎉🔌
9. Link up the NO terminal to your radio's power input (same as step 1, like a power duo). 🤜🤛📻
10. Leave the NC terminal hanging, it's not invited to this switch bash. 🎈👋
This setup should let you party on with your potentiometer as an on/off switch. 🎸🔛🔇
Just make sure to give your potentiometer's datasheet a high-five 🤚📄 to confirm you're wiring it the right way. And no worries, we won't be skinning any cats here! 😺🙅‍♂️ Keep it groovy! ✌️😎
Donate here
Windwalker
Handle: Windwalker
Real Name: Clifford Stewart
Call Sign: KD8QHS
Antenna: K-40// Hustler MagMnt
Radio: Cherida S890
Post by Windwalker »
Does that make the " resistance " the same as " reluctance "
Otishawk15
Handle: Hawk
Real Name: Mik’e
Well it has a 6 wires coming from the radio but my pot only has 5 pins. Just like a cobra. Also this is volume control too. I may have left that out. 2 for on / off 3 for volume. Now I got 1 extra wire. Now my volume works backwards. Guess I hooked the volume up backwards. Some first day huh😊
