Kenwood TS-430S
- Handle: PNW151
- Real Name: Terry Ashcraft
- Antenna: Wilson
- Radio: Galaxy 959
Kenwood TS-430S
I was given a Kenwood TS-430S awhile back, had to do a little work on it, clean relays, replace some caps and resistors, now it's working okay but could be better. Looking at a few sites for upgrades to this radio that I think I'll do in the next couple of weeks. So far it works, puts out about 50 watts AM and about 175 SSB. The AM receive audio is real mushy and from what I read this is a common issue with this radio. Now all I have to do is get a decent 11 meter antenna, I currently have it on a long wire.
I was given the TS-430S radio, PS-430 power supply, SP-430 Ex. Speaker and the AT-230 Antenna tuner.
I worked for 35 years as a communications engineer so radios are not that foreign to me.
Re: Kenwood TS-430S
Kenwood is a nice radio, that model has a bit of lacking in receive but does have a preamp. 11m mod is easy plus it opens the radio to transmit on all the amateur HF bands. The manual can be found on a site called "RigPix", look it up as they aren't a sponsor for us.
- Handle: PNW151
- Antenna: Wilson
- Radio: Galaxy 959
Re: Kenwood TS-430S
Thanks for the info
Re: Kenwood TS-430S
Most of the older ham radios wasn’t much on AM, they really weren’t designed for it. I think your 175w reading is a bit high, think the tubes in it were only good for about 120w, AM is less than a third of that. Correct me if I’m wrong but I think that radio had FM as an option, if the module is installed you got a good bargain.
3’s
3’s
- tramd
- Handle: Drifter
- Real Name: Brian
- Radio: Tram
Re: Kenwood TS-430S
The TS430 is a solid state radio. No tubes.
Post Merge Complete
Added 3 minutes 2 seconds after previous.
The TS-430S is a solid state radio. No tubes and FM was an option.
Post Merge Complete
- Handle: PNW151
- Antenna: Wilson
- Radio: Galaxy 959
Re: Kenwood TS-430S
The TS-430S doesn't have any tubes and the FM option isn't installed. I think free is a good bargain no matter how you look at it. Gives me something to tinker on.
Re: Kenwood TS-430S
True, FM is only needed for the 10m repeater portion of HF.
3’s
3’s
