SWR Reading
- matrix127
- Mud-Duck Sr.
- Handle: matrix127
- Real Name: b morrison
- Radio: cobra
SWR Reading
Maybe this is a dumb question, I have a rm 503 hd amp inline before the antenna, and with amp off i get a flat match. When i turn the amp on it goes to 2.5 without recalibrating, But when i recalibrate with the amp on it's 1:3.What i'm asking is do you recalibrate with the amp on and if so is my swr reading a proper reading with amp on
thank you
thank you
- Blue Ox2
- Handle: Blue Ox
- Real Name: Mike
- Call Sign: KC3LAV
- Antenna: DR-Dipole, Copper "J"-Pole, IMax 2000, MFJ 1740, and a "Slinky" 40M dipole
- Radio: President McKinley&Washington+142GTL Direct Injected by Leadfoot Labs
Re: SWR Reading
Make sure you change the watt reading on your meter. You could be getting the sad readings when your meter is still on 10 Watts. I don't know for sure, but I love the RM KL 503. Gotta be sure everything is set right when you transmit. On AM, pre amp off, correct wattage, lol, all the things I mess up all the time.
73,
Mike
73,
Mike
How do you do from Blue Ox2
KPA223 on the Galaxy DX 2517
Re: SWR Reading
Yes, you have to recalibrate because of the additional wattage.
- matrix127
- Mud-Duck Sr.
- Handle: matrix127
- Radio: cobra
Re: SWR Reading
ThanksBlue Ox2 wrote: October 13th, 2020, 11:47 am Make sure you change the watt reading on your meter. You could be getting the sad readings when your meter is still on 10 Watts. I don't know for sure, but I love the RM KL 503. Gotta be sure everything is set right when you transmit. On AM, pre amp off, correct wattage, lol, all the things I mess up all the time.
73,
Mike
- NLToontje
- Handle: 19AR1970
- Real Name: Toontje
- Antenna: Imax 2000
- Radio: President Lincoln (1st gen.)
SWR Reading
This is why I like a cross needle SWR meter over a traditional meter.
With a cross needle meter I instantly see if both values (output power and reflect) are within range of what I expect. And that in all power settings without recalibrating.
