Cobra 29 variable power
- electrotech
- Handle: Magyver
- Real Name: christopher
- Antenna: Maco V 5/8
- Radio: Cobra 29 Base mod
I've searched some topics with no luck for my issue and my issue is I have to turn the knob to the 1 'o'clock position before variable power reaches 1 watt... I've tried a 10-20k pot and I believe I may need a linier taper instead... Ideas? Its just really annoying... If a linier taper would be best what value would be recommend
Always learning and sometimes forget
Christopher
Christopher
Re: Cobra 29 variable power
I think CB World has a potentiometer that will work fine for a variable power. It is a dual pot so you don't lose the existing control. Check them out, they are a sponsor so if you order from him tell him you are a member here.
- BrownDogAudio
- Handle: CreekRock
- Real Name: Chuck
- Antenna: Homebuilt J-Pole (The Creek Pole)
- Radio: Cobra 2000, Galaxy 959, Drake 4 Series RX/TX/AMP, D&A Maverick 250, Drake L4B, Homebuilt Big Tube Boxes (The hammer brothers, Jack and Sledge), Hallicrafters SX-110 (SWL)
How is the pot connected to the radio? Straight to both sides of jp36 or are you using a tip120 variable?
Brown Dog Audio
AM 26.775 - CreekRock
LSB 27.385 - 942 (WBDA)
Zello App - Brown Dog Audio
CBRT Member # - 31610
American Eagle # AE(Coming Soon)
World Radio # WR(Coming Soon)
World Wide Sidebanders # WWS1942
Sidebanders of America # SOA942
"If what I say offends you, maybe you should look in a mirror and figure out why....."
