HAPPY BIRTHDAY BOMBERO!
CBRT has been
D&A "Raider" boat anchor
Blue Ox2
Handle: Blue Ox
Real Name: Mike
Call Sign: KC3LAV
Antenna: DR-Dipole, Copper "J"-Pole, IMax 2000, MFJ 1740, and a "Slinky" 40M dipole
Radio: President McKinley&Washington+142GTL Direct Injected by Leadfoot Labs
#390230
Post by Blue Ox2 »
Well, I put some "new" tubes in the D&A "boat anchor". Seems to be making forward progress
Not sure if my tuning has made much difference.
Can't really tell if moving the load setting has made a difference either.
I am showing about 40W swing on positive modulation.
This evening I'll try for a local radio check.
73,
Mike
How do you do from Blue Ox2
KPA223 on the Galaxy DX 2517
Kruser
Mud-Duck Sr.
Mud-Duck Sr.
Handle: Kruser
Real Name: RANDY BRUMBACK
Call Sign: W4CPT
Antenna: Moonraker
Radio: Kenwood 440
Re: D&A "Raider" boat anchor
#390542
Post by Kruser »
Your power supply filter capacitors are one of the most important things in a tube amp. The Raider has 3 of them. I just completed a rebuild on a Raider this week. Today you can get larger value caps that are smaller than what D&A had in the 70s. I upgraded mine to hold more power and used 500 volt ratings.
Have you checked yours? Something is wrong if that is all your getting out of it.
Blue Ox2
Handle: Blue Ox
Real Name: Mike
Call Sign: KC3LAV
#390544
Post by Blue Ox2 »
Hey there Randy,
Would you be willing to take on the project of getting this thing working proper if possible?
73,
Mike
Kruser
Mud-Duck Sr.
Mud-Duck Sr.
Handle: Kruser
Call Sign: W4CPT
Antenna: Moonraker
Radio: Kenwood 440
#400063
Post by Kruser »
I just found your reply here a year later. I hope you got it up and running. As for time working on radios and amps, I am up to my neck now with work. I need to be faster but I am so particular at getting things right, it really slows down what I can get done. 73s and wish I could have helped you more.
Randy
nk14zp
Handle: shorty
Real Name: dale
Radio: saturn turbo
#400064
Post by nk14zp »
Caps in all old tube equipment is suspect. Also a variac can be handy working on old tube stuff.
Kruser
Mud-Duck Sr.
Mud-Duck Sr.
Handle: Kruser
Call Sign: W4CPT
Antenna: Moonraker
Radio: Kenwood 440
#400065
Post by Kruser »
I have a lot of test equipment but a variac is something I need to get. I agree it is always the best not to just throw 120 volts into equipment that is old or has not been used in quite a while. And 1,000 volts to old dried capacitors can cause the 4th of July to come early.
Does anyone have a suggestion of what to buy or what not to buy? There are several on fleabay but like anything else, you get what you pay for.
Randy
nosaj
Handle: nosaj
Real Name: Jason
Radio: cobra 29 ltd
#400068
Post by nosaj »
Variacs are nice but a dim bulb tester has saved my bacon many times. It's basically a go no go device and simple to build. Basically if you have a short the light bulb soaks up the current saving your parts if say you put a cap in backwards.
Here's some info[Please login or register to view this link]
nosaj
N1EBC
nk14zp
Handle: shorty
Real Name: dale
Radio: saturn turbo
#400069
Post by nk14zp »
I also wired a bulb in series with my variac. Replace bulb with fuse for full power.
Blue Ox2
Handle: Blue Ox
Real Name: Mike
Call Sign: KC3LAV
#400070
Post by Blue Ox2 »
The project still stands, that is a fact. If and when you have the time and desire, I have the project for you....
73 fer now, we'll be scannin' the waves...…
Mike
Kruser wrote: Nov 15 2019, 13:09 I just found your reply here a year later. I hope you got it up and running. As for time working on radios and amps, I am up to my neck now with work. I need to be faster but I am so particular at getting things right, it really slows down what I can get done. 73s and wish I could have helped you more.
Randy
