Ranger RCI 2995DX amp mod
If you need assistance with a radio modification or have any questions, this forum is the perfect place to ask. Feel free to pop in and join the discussion!
#389996
Hi Guys,
Here is the plan, I want to install a 7pin din jack on the back of my 2995Dx to use a Icom interface cord to a Ameritron ARB-704. Then I could run any ham amplifier on the market. I already have;
Image Image Image
And of course the amp.
The 12v power source will be the same as running the fan on the back heat sink. The key source is the yellow wire at J113, it has +/-5v+ when keyed and 0v unkeyed, the negative or ground will be the chassis. This will work with the ARB-704.The interesting part is going to be figuring out where to connect the ALC so I can adjust this from the radio.
Looking for some help!?
jon6667
Real Name: jon
Antenna: dipole
Radio: icom 7300
Re: Ranger RCI 2995DX amp mod
#390042
Post by jon6667 »
i have the same radio i use the rci on cb and my icom 7300 for hf seeing im i ham with loce for cb i guess that makes me a bad operator
