CBRT has been
Humming
EZ CHOPPER
Real Name: Edward
Humming
#387806
Post by EZ CHOPPER »
When I talk on the radio people on the other side say I have a humming in there when I'm talking that with or with out the amp on and its not the mic gain I turn it all the way down don't help. My SWR are 1.3 to 1.4 cant figure why this would be happening.
295 antenna
Handle: 2950 or 295
Real Name: Charles Reney
Antenna: patriot, Discone
Radio: Stryker 955 , Browning Mark iv
Re: Humming
#387808
Post by 295 antenna »
are you running a power supply? Could be a 60 cycle hum from a poor ground
Handle: Jesse James Dallas
Real Name: Jesse
Radio: working
Re: Humming
#387809
Post by jessejamesdallas »
What radio?
Some radios that have the back-lit face plate will do that...there is a fix, it involves taking the cover off and pulling wires to the face plate lights away from the wires hooked to the mic jack.
[ Post made via Samsung Galaxy S5 Active ] [ external image ]
Re: Humming
#387813
One of the locals here has an aquarium pump right next to the radio.
EZ CHOPPER
Real Name: Edward
Re: Humming
#387817
I believe I'm driving it to much in the amp will see tonight what happens
Re: Humming
#387819
EZ CHOPPER wrote: November 13th, 2017, 7:25 pm I believe I'm driving it to much in the amp will see tonight what happens
Does it hum with the amp off?
EZ CHOPPER
Real Name: Edward
Re: Humming
#387822
was doing wile it was on then someone said it would do it wile the amp was off but not as bad
Re: Humming
#387824
If your equipment is all sitting on the same bench or desk you might want to get some "non slip drawer liner" to place under it, that will help stop the vibration of the transformer being picked up by the microphone. It comes in a roll and you can cut it to size needed.
EZ CHOPPER
Real Name: Edward
Re: Humming
#387835
That is a good idea I still probably going to do that. I had the variable power to low on the amp and the radio turned up to high I reversed it works fine now. Thanks for the info guys.
Stoneman
Handle: Stoneman
Real Name: Junior
Antenna: One Shot Dipole
Radio: Cobra 2000 GTL
Re: Humming
#387879
Post by Stoneman »
I get that as well when I have one of those phone chargers plugged in the wall, or power supply for computer speakers..Mine would do it, then change radio's, it would do it..So that's what I found out no hum when I unplugged them..
