Get a better experience by installing our free app!
Not now
Get a better experience by installing our web app!
Hide
How to do it?
In Safari, tap on the menu bar. Scroll down the list of options, then tap Add to Home Screen.(If you don’t see Add to Home Screen, you can add it. Scroll down to the bottom of the list, tap Edit Actions, then tap Add to Home Screen.)
Connect with CB radio enthusiasts at CB Radio Talk Forum. Fuel your knowledge, unlock secrets, and engage in discussions. Join a vibrant community of like-minded individuals and explore the exciting realm of CB radios.
I have a in line SWR and Watt meter in my vehicle at the moment. When I got it when I was having trouble with a uniden i ran in the past. Since then I have just left in in there. When I get the new radio, should I be concerned about the SWR? I have a Wilson 1000 trunk mount and will be using a SWP Connex 4600 turbo. In the past with the SWP General Washington. I hooked it up and SWR was like 1.3. That was with no adjusting. Just hooked it up.
I WOULD CHECK MY SWRS IF YOU ARE RUNNING A DIFFERENT RADIO. I WOULD TRY TO GET MY SWRS A LITTLE LOWER IF POSSIBLE. MAYBE AROUND 1.1 THAT IS JUST MY OPINION OF COURSE.
STICKMAN
Thanks, Ill keep it. The advise. I will also get those SWRS down. Thanks Stick. Hey, you still got the itch for the 4600. I talked to my buddy. He will go as low as 225 shipped on the 4300 HP.
