NC 100 NOISE SUPPRESSOR Noise Chopper
Mr. Fixit
#39665
Post by Mr. Fixit »
I am running a Uniden pc68xl mobile in my house as a base with a Pyramid Power Supply PS-7KX. I have a 18 Ft Fiberglass Antennae Approx 50 ft high (Grounded.
My problem is Crackling Static Noise!!!!!
Will this Noise Suppressor Help Eliminate most of my noise??
Thanks For any help........My Radio is Peaked & Tuned.
moved by bozo... wrong area
KEEP-IT-REAL
#39733
Post by KEEP-IT-REAL »
First check your grounds. GROUND!! GROUND!! GROUND!!
If your still getting the poping noise or noise from your alternator. Go to radio shack and buy yourself a ground loop isolator filter.
Mr. Fixit
Noise Chopper
#39763
Post by Mr. Fixit »
My Antennae is grounded great with a 8 ft copper stake in ground.
This is my base station, no alternator here.
Please Answer my question, Thanks
Choirboy
#39764
Post by Choirboy »
I ran a wire from the chassis of my radio to the little screw in the middle of the wall outlet my power supply is plugged into. That got rid of my noise problems.
SmallTruckBigRadio
#39770
Post by SmallTruckBigRadio »
Don't do the noise chopper. I learned the hard way that it is junk. I will chop 80% of the noise, but will also chop 20% of the signal.
There are decent TVI type filters, but that ain't it.
Is your RF gain turned all the way up? If you turn the RF gain down a bit, are you still able to hear decent signals?
Is the sound that you are hearing more like a hiss, or a crackling sound?
Does the sound stop with the coax disconnected?
Rex_foxhound
#39774
Post by Rex_foxhound »
and to add to that: is the noise on every channel?
BigBubbaBD
#39775
Post by BigBubbaBD »
How close are you to powerlines or anything of that nature?
KEEP-IT-REAL
#39783
Sorry, missed the part about base. Noise chopper will block you signal like they said. Try a 3 prong extention cord and try another outlet in the house or bypass the power supply and take a car battery and see if you still get the noise. Power supply could be back feeding.
SmallTruckBigRadio
#39810
KEEP-IT-REAL wrote:Sorry, missed the part about base. Noise chopper will block you signal like they said. Try a 3 prong extent ion cord and try another outlet in the house or bypass the power supply and take a car battery and see if you still get the noise. Power supply could be back feeding.
Good advice KEEP-IT-REAL,
Choirboy is running an unusual antenna installation, that just sprouted much larger ears, an A-99.
If I "crank up" the Receive Gain on my radio, I get a bunch of noise too. But, that noise is normal. It's in the air. I can hear traffic lights changing with it cranked up that much. I can hear 5 watt mud-ducks 15 miles away, that are buried in atmospheric noise, with it turned up that much. If I re-install the Wilson Silver load (fiberglass antenna), the noise disappears, but so does much of the signal.
When I turn down the receive gain to a barely noticeable level, any decent radio will come in just fine.
Does the noise change if the antenna pipe is either grounded or un-grounded? If you are grounding to piping, or the buildings electrical ground, I am wondering if the buildings electrical system is sending noise up from the ground wiring?
