10 Mater Contest
Let's just talk skip... a great place to join the prestigious CB radio Hall of Fame.
Circuit Breaker
Handle: Circuit Breaker
Real Name: Stephen
Call Sign: K7CB
Antenna: OCF Dipole
Radio: HR2510/Yaesu FT-950
10 Mater Contest
#350906
Post by Circuit Breaker »
I don't have much of a station right now - at least antenna wise. Just a 75/80 meter off center fed dipole with the feedpoint at 40' going to a Yaesu FT-950. I decided to try out the ARRL 10 Meter Contest anyway - just to see who I could work as I sat at the desk doing an assignment for my Software Requirements Engineering class due on Monday evening. I worked a total of 31 stations. Most were on the east coast. But I did work Mexico, Columbia, Brazil, Canada (Ontario and Yukon Territories), four Japan stations, Australia, Germany and finally Scotland. Not bad for 100 watts into a dipole not really meant for 10 meters.
Yaesu FT-950
Yaesu FT-8100
Uniden Washington Base
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
De_Wildfire
Handle: De_Wildfire
Real Name: Greg
Antenna: Imax 2000. Hex Beam, G5RV dipole, Jpole(UHF/VHF) Austin Suburban Tri Band (UHF/VHF)
Radio: Washington, Tram D201, Tram D64, Robyn 520D, Cobra 139XLR, Elecraft K3S, Kenwood 590S, Yaesu FTM 400DR, Alinco DR-235, ADI-146
Re: 10 Mater Contest
#351300
Post by De_Wildfire »
That is great. My inverted L and inverted V antennas don't work well on 10 meters because they are low banders but I can work the world like Japan, South Africa, Russia, New Zealand, Austrailia, Sounth America, Hawaii, Alaska all of Europe and parts of Russia on my Imax 2000 vertical that sits on a 13 foot pole. It seems like your antenna may have an advantage over my inverted L cut for 75 meters and my G5RV dipole. That is great that you can get it to work up around 10.
Circuit Breaker
Real Name: Stephen
Call Sign: K7CB
Antenna: OCF Dipole
#351306
I have a 2 element SteppIR Yagi...actually, I have two. The first one took a lightning strike a year and a half ago that fried the controller. My homeowner's insurance replaced it - hence the second 2 element Yagi. I just haven't had time to put it and the tower up since moving. I'm hoping to get started this Spring. When I start putting the new antenna together, I want to test the stepper motors on the old antenna. If they work, then I want to pull some money together and turn the new 2 element into a three element. It won't really get me much overall - adding an element doesn't do much for the forward gain but it does increase the front to back ratio a bit. But I figure I have most of the parts, I might as well use them. :biggrin:
Yaesu FT-950
Yaesu FT-8100
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
