CBRT has been
wiring Question
Night Eagle
Real Name: David
Antenna: Solarcon A-99
Radio: SWP RCI 2980WX
wiring Question
#324042
Post by Night Eagle »
My new radio is scheduled for delivery today. My current radio has the power wire run to the battery. The ground wire is connected to a bolt under the dash and it has worked fine. Is that OK or should the ground also go to the battery?
yamaha
Real Name: Mike
Antenna: A99,M103,60rohn
Radio: 2950DX--2000GTL
Post by yamaha »
If its a low power radio (less than 30w) than the frame ground is fine.
73s from your nextdoor neighbor 919 Yamaha out of Willow Spring NC
2950DX - 2000GTL - 148GTL - 29LTD - 19Plus - 3300HP - DX959 - Galaxy SIRIUS (some type of RCI creation)
Night Eagle
Real Name: David
Hello fellow North Carolinian. Thanks for the response. I will be installing a SWP Gereral Lee but no amp yet.
yamaha
Real Name: Mike
Post by yamaha »
10-4 on that youll be fine with your setup just use a good auto-grade fuse at your battery and one at your radio. Fuses save radios. 73's
Night Eagle
Real Name: David
Thanks Yamaha. By the way, is Willow Spring near Fuquay Varina? What channel do you guys use?
yamaha
Real Name: Mike
Post by yamaha »
I went to Fuquay Varina high school. Most the locals around NC talk on 36lsb and 30am. The old timers get on 30am everyday around 8 in the morning and again around 11 every night. You normaly can key up and hit someone on 36lsb anytime of day.
Night Eagle
Real Name: David
Okay. Thanks again for the info. Now just patiently waiting for that UPS truck to pull in my driveway...
