Question about battery banks.
- RadioPR
- Super Mud-Duck
- Radio: RCI 2990 | RCI 2950
Hello, this is my first post. I need/want to have my station ready in case of a power outage. I want to get two, maybe four, gel batteries and here is my question. I currently have a 25Amp Power Supply which powers up my rig (RCI2950 barefoot), is there a way to have this hooked up to my batteries and use this power supply to maintain my batteries charged up 100% Do i need to put anything between the Power supply and the battery bank? I also have a piramid 10amp power supply could that be used to maintain the battery bank instead? more like a deep cycle charger?
Hurricane Season coming up so i want to have this up and running/charged up and working.
73's from Puerto Rico!
thank you in advance
- Night Crawler
I used an Isolator between them on a 2 meter repeater that I had something like this.RadioPR wrote: I currently have a 25Amp Power Supply which powers up my rig (RCI2950 barefoot), is there a way to have this hooked up to my batteries and use this power supply to maintain my batteries charged up 100% Do i need to put anything between the Power supply and the battery bank?
http://www.legitimate.org/ioo ... olator.htm
Here is a modification that can be done if you have an Astron supply.
http://www.repeater-builder.c ... ttmod.html
- RadioPR
- Super Mud-Duck
What if i have a Nippon America DVP-2212 power supply? Is there any other simpler mean of achieving this?
- norstadt
- Real Name: mike
Don't know if this will help you or not, however I have 2 cell site batteries that run in parallel w/ each other. I have a 2000 watt invertor tied in that powers (120Vac) my back up 3/4 HP sump pump. I also run a DX250 amp off the bateries direct. To charge my batteries I took a 13vdc/1000mA power transformer and use that to provide a constant trickle charge to the batteries. Its been 2 yrs running w/ no ill effects what so ever. Never had the batteries go out either. Once in awhile I test the voltage and it reads 14vdc. Stays charged up well. Whenever a storm causes power disruption my backup sump pump keeps the basement dry. I also tested the batteries out and ran the sump pump by itself for 2 weeks untill batteries fell below 12v. Like I said not sure if this helps you or at least gives you an idea?
Mike
Mike
443 Arizona Verified
- Mod Duck
- Handle: Double R
- Real Name: Steve
- Radio: madison on 5/8 wave
hey thanks Nightcrawler, i only wish i knew of the Astron mod sooner,,, it got zapped (backfed),
- RadioPR
- Super Mud-Duck
Hey norstadt, thank you for your input. Night Crawler's suggestion is excellent but that type of setup is much more highend to what im trying to achieve, also out of my reach ($$). I already have three (3) batteries here hooked up and working. I am looking for something cheap and simple, as that of what you are suggesting, thank you.
I will give this a try and see how these batteries stay charged.
Thank you again.
Thank you again.
Go to Walmart and buy 3 cheap "float" chargers, I use them on my 12 volt system on my golf cart(for the CB, Stereo, etc.) and I bought them for 7 bucks!!!
