16 Pill Amp Schematics - With Pictures
- WESTGATE
- Handle: WESTGATE
- Real Name: randall robles
The more watts you swing, the more people you bring. BREAK!
- WESTGATE
- Handle: WESTGATE
16 pill schematics "part2"
parts list
R1, 2, 3, 4, 5, 6, 7, 8
29, 30, 31, 32, 33, 34
35, 36 10Ω 1/2W Carbon Film Resistor 16 Brown-Black-Black
R9, 10, 11, 12, 13, 14
15, 16, 17, 18, 19, 20
21, 22, 23, 24, 25, 26,
27, 28, 37, 38, 39, 40,
41, 42, 43, 44 100Ω 2W Carbon Film Resistor 20 Brown- Black- Brown
R45, 46, 47, 48 4.7Ω 2W Carbon Film Resistor 4 Yellow-Violet-Gold
C1, 2, 63, 64 270pf Silver Dipped Mica Capacitor 4 270 or 271 / 500V
C3, 4, 5, 6, 7, 8, 9, 10
55, 56, 57, 58, 59, 60
61, 62 0.01uf Ceramic Disc Capacitor 16 0.1 or 103
C11, 12, 13, 14, 69,
70, 71, 72 330pf Silver Dipped Mica Capacitor 8 330 or 331 / 500V
C15, 16, 17, 18, 65,
66, 67, 68 1000pf Metal Clad Capacitor 8 1000
C19, 20, 21, 22, 23,
24, 25, 26, 47, 48, 49,
50, 51, 52, 53, 54 120pf Silver Dipped Mica Capacitor 16 120 or 121 / 500V
C29, 30, 31, 32, 33,
34, 35, 36, 37, 38, 39,
40, 41, 42, 43, 44 .1uf Ceramic Disc Capacitor 16 .1 or 104
C27, 28, 45, 46 150 pf Metal Clad Capacitor 4 150
C73, 74 82pf Silver Dipped Mica Capacitor 2 82 or 820 / 500V
C75 40-50pf Silver Dipped Mica Capacitor 1 40-50 / 500V
C76 25-150pf Tube in Tube Variable Capacitor 1 PSF# VC150
C77 22 uf Electrolytic Capacitor 1 22 uf / 25V
C78 10 pf Ceramic Disc Capacitor 1 10
D1 3A / 1000V PIV Silicon Rectifier 1 1N5408
D2 1A / 1000V PIV Silicon Rectifier 1 1N4007
D3 Glass Signal Diode 1 1N4148
D4 LED Indicator assy. 1 Green LED / Resistor Pkg.
D5 LED Indicator assy. w/ 18” GND Lead 1 Red LED / Resistor Pkg.
TR1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13,
14, 15, 16 250 Watt RF Power Transistor 16 2SC2879
TR17 NPN Switching Transistor / TO-92 1 PN2222A
FC1, 2, 7, 8, 9, 10,
11, 12, 13, 14, 15,
16, 17, 18, 19, 20,
30, 31, 32, 33, 34,
35, 36, 37, 38, 39,
40, 41 1/2” x 1/2” Ferrite Core 24 PSF# FC.5
FC3, 4, 5, 6, 21, 22,
23, 24, 25, 26, 27,
28, 29 1/4” x 1/2” Ferrite Core 13 PSF# FC.25
T1, 2, 3, 4, 5, 6, 7, 8 1/2” x 1/2” Ferrite Transformer Core 8 PSF# FT.5
T9, 10, 11, 12, 13,
14, 15, 16 .825” x 1-1/2” Ferrite Transformer Core 8 PSF# FT.825
SW1 SPST Switch 1 PSF# SW1
RLY1 DPDT Relay 12V Coil /20A Contacts 1 PSF# RLY20
FAN1, 2, 3, 4 4.7” Fan Assy. 4 PSF# FAN4.7
FG1, 2, 3, 4 4.7” Fan Guard 4 PSF# FG4.7
Conn1, Conn2 Panel Mount SO239 UHF Connector 2 PSF# SO-239B OR SO-239T
Conn3 1/4” Stereo Phone Jack 1 PSF# PJ-2
Cabinet Aluminum Enclosure Assy. 1 PSF# AE-GRAND
HS1, 2 Aluminum Heat Sink 2 PSF# AHS-LG
CB1 Pre-Drilled Copper Clad Circuit Board 1 PSF# CCB-GRAND
CB2 Power Buss Circuit Board 8” x 1” 1
PS1, 2, 3, 4 8 Position Pre-Cut Transistor / Pill Strips 4 PSF# PS8X
SCK1, & SCK2 LED Mounting Clip (with D4 & D5) 2
WIRE-1 40” Length of #20 Silver/Teflon Wire 1 PSF# TEF20
(8 x 5” / Input Transformer Chokes)
WIRE-2 320” Length of #16 Silver/Teflon Wire 1 PSF# TEF16
(4 x 25-1/2” / Input Transformer Windings)
(4 x 40” / Output Transformer Windings)
(8 x 6” / Splitter & Combiner Windings)
(2 x 2-1/2” / CONN1 & CONN2 to RLY1 Leads)
(1 x 5” / C76 Lead)
WIRE-3 66” Length of #14 Silver/Teflon Wire 1 PSF# TEF14
(8 x 8” / Output Transformer Power Chokes)
(1 x 2” / RLY1 Jumper)
WIRE-4 25” Length of #22 Hook-up Wire (Red) 1
WIRE-5 26” Length of #22 Hook-up Wire (Blue) 1
WIRE-6 12” Length of #20 Hook-up Wire (Red) 1
WIRE-7 24” Length of #8 Red Power Cable 4
BRAID 3” Length of Ground Braid w/ Bolt & Nut 1
COAX 136” Length RG316 High Temp Coax 1 PSF# RG316
(4 x 19” / Input Coax Cables)
(4 x 15” / Output Coax Cables)
#12CW 24” #12 Solid Copper Wire 1
(2 x 12” / L1 & L2 Loading Coils)
HDW1 Hardware Kit (See Below)
SHCS #4 40 x 1/4” Socket screw 32
(Transistor Mounting)
SHCS #6 32 x 1/4” Socket screw 14
(Enclosure Cover Mounting)
Pan Head Sheet Metal Screw 6
(Main Board to Enclosure Mounting)
Pan Head Machine Screw #6 32 x 1/2” 8
(SO-239 & Rubber Feet Mounting)
Pan Head Machine Screw #6 32 x 3/16” 12
(Main Board to Heat Sink Mounting)
#6 Lock Washer 6
#6 32 TPI Machine Nut 4
(SO-239 Mounting)
#6 Solder Lug 6
(SO-239 & Fans)
Pan Head Machine Screw #8 32 x 1-1/2” 16
(Fan Mounting)
#8 32 TPI Machine Lock Nut (NYLOCK) 16
(Fan Mounting)
Rubber Feet 4
Bushing 1
Heat sink lubricant 1
Label Sheet 1
1/2" Length 1/8” Heat Shrink Tubing 2
4” Cable Tie 8
parts list
11, 12, 13, 14, 15,
16, 17, 18, 19, 20,
30, 31, 32, 33, 34,
35, 36, 37, 38, 39,
23, 24, 25, 26, 27,
T9, 10, 11, 12, 13,
(1 x 5” / C76 Lead)
#6 Lock Washer 6
(SO-239 Mounting)
#6 Solder Lug 6
(SO-239 & Fans)
(Fan Mounting)
(Fan Mounting)
Rubber Feet 4
Bushing 1
Label Sheet 1
4” Cable Tie 8
