CBRT has been
Desprite to get on the air
MacGyver
#221479
Post by MacGyver »
With the winter and the weather I haven't had a chance to get up on the roof and set up my new starduster. I have been trying to think of a way to set something up just to get me on the air. I have a barn that I was thinking of putting a mobile unit in but the barn has a metal roof. So I am thinking about taking my magnet mount antenna and sticking it on the inside of the metal roof upside down. Not sure how well this would work but any other thoughts or ideas would be great.
MacGyver
Re: Desprite to get on the air
#221482
Post by MacGyver »
Or what if I just take the antenna and just put it up in my attic? it won't be on any metal would that affect anything?
Ricky bobby
#221533
Post by Ricky bobby »
ON THE BARN'S METAL ROOF SHOULD BE AIGHT!
PONY EXPRESS
Radio: GOLDEN EAGLE Mark IV
#221545
Post by PONY EXPRESS »
MacGyver wrote:With the winter and the weather I haven't had a chance to get up on the roof and set up my new starduster. I have been trying to think of a way to set something up just to get me on the air. I have a barn that I was thinking of putting a mobile unit in but the barn has a metal roof. So I am thinking about taking my magnet mount antenna and sticking it on the inside of the metal roof upside down. Not sure how well this would work but any other thoughts or ideas would be great.
Inside the building it just wouldn't do very well with that metal roof. Now if you put it on top of the metal roof that would be aok and work.
Spring is just a few weeks away good luck on the antenna project mine starts March 29th when we take a full weeks vacation
linx
#221561
Post by linx »
It'll work...not great, but it will work. I've talked to a friend that had a mag mount on a 55 gallon barrel for a couple of month's. Not very efficent.
Another alternative would be to put the starduster together and put it in a tree, or on a pole somewhere in your yard? If you have a chain link fence you can bolt it to a post. There's lots of options. Like PE said, spring is just a few weeks away.
MacGyver
#221643
Post by MacGyver »
Well I put the mobile antenna in the attic but my swr is close to 3 what can I do to get it lower?
PONY EXPRESS
#221653
MacGyver wrote:Well I put the mobile antenna in the attic but my swr is close to 3 what can I do to get it lower?
Think MacGyver Think ! What would the real MacGyver do ? Antenna has no ground plane in the attic .. Use the metal roof on the barn !!!!!
Thats what The Real MacGyver would do.... then adjust length of antenna for swr.
The higher the channel " frequency " the shorter the antenna so on channel 1 the antenna is longer than channel 40
