Coax in door
- The Bull
- Handle: Thebull
- Real Name: John
- Antenna: Predator 10k
- Radio: Conrad 29ltd “sparky tuned”
Coax in door
I saw this guy today with his coax shut in his door is this a bad idea?
- Foxhunter
- Radio: Fisher-Price
RE Coax in door
Hope you're not serious--------it wasn't you was it ?? It's real bad as the center-conductor will be forced closer to the shielding developing into a major problem for sure. He'll find out.The Bull wrote:I saw this guy today with his coax shut in his door is this a bad idea?
- The Bull
- Handle: Thebull
- Real Name: John
- Foxhunter
Well I guess that's true I'm using large diameter coax wasn't really thinking about mini-8 / RG58 or 174 those would seem thin enough to slip in with the foam gaskets without too much compression. Sorry wasn't thinking I run a heavier 214 cable and it goes thru the firewall. I know it's not good practice if there are pinch-points, kinks and repeated flexing and have seen countless coax lengths damaged in such a manner. Perhaps your friend's coax run is okay?
- virus
- Slim Jim
that's how I've always ran my coax...they put the holes right under the seat in my truck. Punch out the little plastic/metal plug and you're good to go. Gromet = very important.virus wrote:i used a gromet in the floor just cut a hole in it and ran through there most cars have one and i know all pickups have one in the back of the cab
- f-250ford
