CBRT has been
Dosy Pre Amp
Easy Rider
Mud-Duck Sr.
Mud-Duck Sr.
Dosy Pre Amp
#159937
Post by Easy Rider »
I have a dosy rec-4 receiver pre amp. I would like to put in line with my base setup. I have a Ranger base station, dosy watt meter, Fat boy amp, not quite sure where and how to put it in-line. Any help would help. Don't won't to blow anything up! Need to make sure I have xmitter and ant. jumpers hooked up right to. Thanks Easy Rider
Slim Jim
Post by Slim Jim »
I think this order will work:
Base Radio = Pre-amp = Fatboy = watt-meter = antenna
start with your antenna coax and put it in the antenna jack on the watt meter, then go from the x-mitter connector on the watt meter to the antenna connector on the fatboy, then go from the x-mitter connector on the fatboy to the antenna connector on the pre-amp, then from the x-mitter connector on the preamp to the antenna connector on the radio...double check and re-check this...and then re-check it again.
