Hooked up my montgomery ward 702 base today. talked great no problems till I turned it off. walked out of room and came back and this base was on, tried to turn it back off and no luck, finally had to unplug the thing. it has a clock in it and alarm settings. all this was turned off as well. I'm not a big fan of plug in bases, but, I have a friend that wants to trade me some other equipment for it and I wanted to make sure it was still in good working order before I traded.
any ideas?
Hooked up anchor today
- unrealantidote
1986 F350
4 speed manual Transmission
6.9L IH Diesel
4x4
35x12.50 BFG T/A tires
Uniden PC76xlw CB
Palomar Elite 250 Linear
Eastcoast 4x2879 box
6.9L IH Diesel
4x4
Uniden PC76xlw CB
- 209 first class
is there a setting for 'waking up to the cb' instead of the alarm buzzer? check that switch, and check the main power switch with a continuity tester. i had a radio where the insides of the power switch(attached to the back of the volume potentiometer) crumbled apart and the thing wouldent shut off.you could hear the insides crunching instead of clicking when you turn the power off. does the click sound normal? 209
