I must differ with you with respect to Part 95 and Part 97. You May NOT use ANY radio on CB, amateur license or otherwise if it not certified for that use. ALL CB radios must comply with Part 95 including FCC certification. Amateur operators MAY NOT use "any radio on CB so long as it complies with "4 watt and 12 watt peak power". Amateur radios may be used on amateur radio in accordance with Part 97 ONLY. A ham MAY NOT use a so-called "export" radio on CB. Want to prove it? READ Part 95 and its equipment requirements for CB Radio. Then LOOK for the certification sticker on the export radio; you will not FIND it!TheCBDoctor wrote:Hi Night Crawler
A Licensed ham operator may use a non type accepted radio on the CB band as long as the Ham operator is licensed and is complying with the rules and limitations of the CB Band. No more than 4 watts carrier and a peak power of 12 watts is allowed. It is up to the Ham operator to make sure he or she is within compliance.
It is illegal for a person without a Ham license to operate a non-type accepted radio, even if it is being used within the compliance of 4 watts carrier and 12 watts peak for CB. It is the commercial sale of the exports that is illegal, but as a Ham operator you may use an export or non-type accepted radio for Ham bands as long as you are within the guidelines of the respective Ham bands.
Ham operators are allowed to build and modify any radio equipment under an "experimental station" exemption as long as the Ham operator is within compliance of the rules and limitations of the band that he or she is using. The rule of thumb is only one experimental station is to be used at a time. The sale of an experimental station to anyone other than a Ham operator is not legal. Building radios on a commercial basis is unauthorized. A Ham operator may possess one 10 meter amplifier at a time per station. If you do not have a Ham license then just the possession of the amp would be illegal whether it is in your closet or on your bench.
Ham operators may build, possess and use export radios on CB if it is on an experimental basis and is not being manufactured for commercial sale, and the Ham operator is within compliance of the use on CB radio. A Ham ticket is a very powerful license. It allows one to have a scanner in their vehicle even in those jurisdictions where scanners are not allowed in vehicles by local ordinances.
I hold an FCC license and may work on any radio legally as long as I do not alter the radio to operate illegally or out of compliance. I may transmit on anything from Marine radios to police radios under the owners license and consent. I may contact the Coast Guard on channel 16 and get a radio check as long as I state who I am, where I am and what I want. The only exception is I may repair Ham radios using a Dummy load, but even with an FCC repair license, I may not make over the air communication, even for a radio check. unless I also possess a Ham ticket.
Ham operators may use any radio on CB as long as it is in compliance within the limitations of 4 watts carrier and 12 watts peak power. No ham operator using any radio is allowed to exceed these limitations, licensed or not. As I stated a Ham ticket is a powerful license. One must have a Ham ticket to operate a M.A.R.S station. the only exception is a commanding officer, or his designated representative, in the military may use the Military Affiliated Radio Service to communicate with other MARS stations and Ham operators. They are the only ones that do not need a Ham license to do so.
Getting a Ham license is much easier now that the code has been dropped as a requirement. I had to learn code when I got my Ham ticket. I don't think that requirement should have been dropped, but they had to do something because the Cell Phone was killing Ham radio. I recommend to any driver or operator to get a Ham license. No official can touch you or your equipment as long as you have a Ham license. This includes scanners and any amp or home made radio, unless it can be proven that you are operating out of compliance.
Respectfully.
A "ham licence is NOT a "powerful" license. It permits one to operate ON the ham bands according to Part 97 and confers NO power to operate in any other band other than that covered by same! MARS is military, and while one must comply with Part 97 AND military regulations, its frequencies are separate and it's actual operation is governed by NTIA. Operators operate with PERMISSION (and training) from their State MARS Directors.
The so-called "scanner exemption" is also a misconception. IT WILL NOT NECESSARILY PROTECT YOUR SCANNER FROM SEIZURE!!! iT IS A COMMON MISTAKE! What it WILL do is protect your AMATEUR transceiver THAT
HAPPENS TO SCAN from overzealous law officers. In some jurisdictions, your Bearcat SCANNER may still be seized, your so-called "license" notwithstanding.
I suggest you check it out; you will find that I have told you the truth. A "ham" license is NOT a free ride to everywhere!
jwalker
