CBRT has been
three element beams
rev ike
three element beams
#87963
Post by rev ike »
any body got specs for a three element beam i want to put up a flat side thanks
Handle: 316
Real Name: Skylar
Antenna: Wilson 5K
Radio: RCI 2950 and IC-7000
Post by 316 »
Screaming Demon has one, could try to Pm him and get some info.
Do you have any pics maybe I could help.
rev ike
three elements
#87970
Post by rev ike »
don't have any pics just have some parts wanna build 3 el. flats need specs though thanks :D
rev ike
beams
#87980
Post by rev ike »
thanks 316 i PMed him, maybe it will work out :D
Handle: 316
Real Name: Skylar
Antenna: Wilson 5K
Post by 316 »
no problem
Mississippifrog
#87991
Post by Mississippifrog »
Heres the instructions (with pics) for a set of Maco 103C
Hope this helps.
rev ike
antenna
#88024
Post by rev ike »
thanks a bunch mississippi frog i copied to my thumb drive so i should be ready when i get all the parts shined up thats just what i needed i lost the paper copy thank you thank youthankyou!!!!! :D ...IM GONE NOW
rev ike
three elements up
#88726
Post by rev ike »
thanks guys i got my 3's up and running so far so good...im gone now
Midlander
#88729
Post by Midlander »
Show us a picture of the install
World Radio 4, The Big 4...GOT DOWN!
Mississippifrog
#88732
Midlander wrote:Show us a picture of the install
I second that motion!!
screamin demon
3 element beams
#88744
Post by screamin demon »
guys just to let you know i did pm rev ike back about the antenna.but by the time i did mississippifrog gave him the web site.but best of luck with the antenna rev maybe you can swing my way at me in the pocanos.hope to hear from you.
rev ike
three elements
#88760
Post by rev ike »
hi guys, i don't have pictures yet but as soon as i can i will post them 4 u thanx a bunch God bless!!! :D
trip7downunder
Post by trip7downunder »
Just wondering that you set up your specs to a maco 103. Are your elements exactly the same as the maco specs. You must have the same to set up for maximum gain as the diameter of the elements affect the resonating frequency. This is called stepped diameter correction. Yagi mechanic is a good program to work out differences in element diameter to resonance. Also check out this site for some different beams . [Please login or register to view this link]. Just my 2 cents. Cheers trip is outta here
rev ike
hi trip
#89037
Post by rev ike »
tried to follow link, language barrier thanks
