Weird interference from gas station.
Becker
#77097
Post by Becker »
When I get close to the gas station in my town I get an extreme amount of static. My meter reads about 6 S units. It's just a steady hiss/whine. Once I'm about 50 yards from the station all problems are gone. Any idea what would cause this?
#77103
Post by 231 »
Lighting probably. There are a ton of man made things that'll produce similar interference...so that really isn't uncommon.
Handle: 316
Real Name: Skylar
Antenna: Wilson 5K
Radio: RCI 2950 and IC-7000
Post by 316 »
Could be fluorescent lights from frequencies transmitting at the pump, to microwaves, there really is no telling.
coondog
#77199
Post by coondog »
same thing happens to me when i go through this one town everyday.dosen"t matter what ch.you go on its there.i just have to tell people to hang for a bit because its so bad i can"t hear them.its a gas station also.
short fuse
#77346
Post by short fuse »
When the Dodge dealer in town is closed I get the same thing,when thy are open,no noise!I think it's the alarm,but anything electrical can do this I suppose.
outlawmobile
weird interferance from gas station
#77492
Post by outlawmobile »
I have found many things cause hash and trash on 11 meters.Neon signs are one of the worst,also as stated earlier fluorescent lights and alarm systems are many times the culprit,the local bank puts out quite a clatter when its closed[must be the alarm what else could it be]I too have to tell people I will get back to them when I get out of town cause sometimes I have as much as 1/2 scale of just white noise[if ya want to call it that]Shawn
Zumlin
#77517
Post by Zumlin »
voice pagers too, real nasty, get that pulsating sound @ S9..
countryboy
Real Name: keith
Radio: connex 3300hp
Post by countryboy »
maby a freq. filter might help. just a thought.
DJboutit
#78425
Post by DJboutit »
I get the same thing when I drive by lots of power lines on all channel
Longhair
Super Mud-Duck
Super Mud-Duck
noise from signs and power lines
#81241
Post by Longhair »
I got the same noise from a car dealers sign. I Installed the noise chopper and now I don't get any noise at all. Its a antenna filter. I also found It was better to use a 3 foot jumper Instead of a 2 Foot jumper. Hope this helps.
countryboy
Real Name: keith
noise chopper thats the name of it. like he said it should help
4x4 in a mud duck pond
CBRT is the place to be
