HAPPY BIRTHDAY BOMBERO!
CBRT has been
Increase receive.
Becker
Increase receive.
#51553
Post by Becker »
I want to know how I can increase my receive and possibly cut out engine, fuelpump, and air conditioner blower noise? It seems like when I drive I have to turn my squelch half way up, it just seems like it though it's not half way up. Anyhow when I'm driving I'll move around on the channels and listen. So I turn my squelch down just a hair and I get static, but I can faintly hear fellas talking. Is there anyway I could cut some of the static to get the guys in more clearly? I have a galaxy 929, 102" whip on a spring, located in the middle of the front bed rail.
EC 174
#51611
Post by EC 174 »
Are your power wires run in to the fuse box or the battery ?
Becker
#51713
Post by Becker »
fuse box, I tried to get my dad to run it to the battery but he wouldn't do it.
Handle: 316
Real Name: Skylar
Antenna: Wilson 5K
Radio: RCI 2950 and IC-7000
Post by 316 »
You need to run it to your battery if possible. It will help reduce some of your noise or feedback anyway, I wouldn't think that your ant. would too much to do with it. How long is your coax. It should be min of 18ft
73's
316
Becker
#51853
Post by Becker »
my coax is 12 feet long, I need to get some longer because I just have it run through the back glass, and under the seat to the radio. Also one irritating thing is when I hit my brakes the switch on the brake pedal makes the needle jump and sometimes i get some static if the squelch is down enough.
Handle: 316
Real Name: Skylar
Antenna: Wilson 5K
Post by 316 »
I haven't heard of anything like that. I have no idea where that would be coming from.
But you need 18' for your SWR's
73's
MR. 450
#51870
Post by MR. 450 »
AND YOU ALSO NEED YOUR SWRS CHECKED AND GET THE RADIOS POWER ON THE BATTERY ALSO IF YOU HAVE THE ANTENNA TO CLOSE TO THE CAB YOU RF WILL CAUSE THE SWRS TO BE HIGH YOU SHOULD TRY TO MOVE THE ANTENNA ABOVE THE CAB OR AWAY BY A FOOT SO THE REFLECT WILL BE LOW AND TAKE THE TRUCK TO A CB SHOP THAT HAS A MFJ METER TO CHECK THE COAX AND THE ANTENNA TO SEE IF THEY ARE MATCHED
Handle: 316
Real Name: Skylar
Antenna: Wilson 5K
Post by 316 »
I completely forgot about that.
Very good point 450
4600 Turbo
#54423
Post by 4600 Turbo »
A in-line filter may take some of the static out if it's coming from your hot wire.
If it's coming in through your antenna its much harder to take out the static you hear from your blower other electrically components in you vehicle.
Start there it might help.
