Need Mic Adapter for Realistic TRC-451
- tonyvlx
- Handle: 007
- Real Name: Tony
- Radio: Anytone AT-6666
Going to be using my CR-577 mic on my newly aquired Realistic TRC-451. Need a adapter to convert Standard 4 pin cobra style to the Realistic 5 pin style.Purchased a adapter made by Workman but was completely wired incorrectly inside. Can anyone recommend a brand/product number so i get the correct one. Thanks
Re: Need Mic Adapter for Realistic TRC-451
Give our sponsor, CB World a call and tell them the radio model, they should have the right one you need.
[ Post made via iPhone ]
the "Workman C4P5DIN cobra 4 pin mic to 5 pin Din RS Realistic adapter" should work on that radio, might need #2 pin connected to #4 pin using a diode. I have seen a few from the factory wired screwy, not just the RS models.
- snowolf
- Mud-Duck Sr.
- Real Name: Denny
Most name brand Mic Companies will provide you with the wiring diagram for the Mic to radio.
- arcone
- Handle: Plastic Radio
- Real Name: Jeremy
- Call Sign: 535
- Antenna: 4 element LFA, Moxon & A99
- Radio: Electrophone CB590 Base
I have found it best to make my own with a section of audio cable and an inline 4 pin male plug, it seems a few of these ones on ebay etc don't work. If you're ok with a soldering iron, the wiring or pin outs are available on line. I run a 4 pin Uniden adaptor patch lead with my TRC-451 DIN type connection.
Jeremy.
Jeremy.
- Mentor3006
- Handle: Mentor / Space City 3006
- Real Name: Dave
- Antenna: Realistic stainless steel 102
- Radio: President McKinley II FCC
And that ladies and gents is why I scoured Ebay for a Realistic noise cancelling power mic when I was running a TRC-465... Good radio, funny mic connector.
Coils = loss.
Base: Realistic TRC-465 with Realistic noise cancelling power mic. antenna and setup in planning.
