roof mount 5ft firestik options
- cdj85
- Super Mud-Duck
- Handle: 454
- Real Name: chris
- Antenna: firestik
- Radio: uniden 520/78
I was wondering if how you guys have mounted the firestiks to the roof. I have a 5ft I was thinking of moving from the fender to the roof and wasn't sure if it would be too heavy and tweak the roof metal.
I saw this mount from bulletproof diesel pn 90201131. Has anybody used it before? What are your thoughts?
I have a link to it but not sure if I can post it here.
A puck is the best roof mount if you are okay at drilling holes, otherwise a tri-magnet mount will suffice. When using any magnet mounts, you have to keep an eye on where the coax enters the vehicle.
Now for a question back, what type of vehicle is this going on?
- cdj85
- Super Mud-Duck
- Handle: 454
- Real Name: chris
- Antenna: firestik
It's going on a 99 F250. I'm not so apposed to cutting a hole in the roof now. Just don't want the roof to get damaged if the weight of the antenna is too much on the highway.
- Mentor3006
- Handle: Mentor / Space City 3006
- Real Name: Dave
- Antenna: Realistic stainless steel 102
- Radio: President McKinley II FCC
Considering the amount of aerodynamic drag / stress antennas like a Predator 10K apply at highway speeds, I seriously doubt your Firestik would be any worse. Find a way to distribute the stress over a wider area though. The predator guys I know that ran them roof mounted, and one guy that ran a 102 roof mounted all used cast off circular saw blades are basically giant fender washers to mount through. Just make sure you get the right size... . I think they just used the metal and drilled a new hole somehow... Been a very long time sorry...
