2008 suburban bigger setup
- saltydog
Have tried everything on this suburban . Am getting dash light and service engine light for fransmission control unit and communications bus now power , ,service 4x4 ,abs , and airbag light , and tire monitor light when unkey Mike after talking tried ferrite on some stuff no change . All grounds go to frame , is a 2008 suburban 2500 . Has a cobra 29 and 5 pill driving a 32 pill . Running 24 lto cell batteries and super cap under hood . Running 2 mechman 400 alternators has no voltage drop . Any help with larger amps in a 2007-2014 suburban would be great .
- 13
Re: 2008 suburban bigger setup
Wow, 32 pill, would like to see pics once you meet the forum’s requirements. That is a lot of RF so the most important thing other than grounding all the electronic components is bonding all the vehicle body components, hood, doors, back hatch, etc.
You probably won’t stop the lights from blinking, led’s don’t have any kind of shielding, you might have to go to incandescent bulbs, you can try shielding the computer and fuse box with aluminum foil to see if it helps with the malfunctioning.
@saltydogsaltydog wrote: ↑November 4th, 2023, 2:49 pm Have tried everything on this suburban . Am getting dash light and service engine light for fransmission control unit and communications bus now power , ,service 4x4 ,abs , and airbag light , and tire monitor light when unkey Mike after talking tried ferrite on some stuff no change . All grounds go to frame , is a 2008 suburban 2500 . Has a cobra 29 and 5 pill driving a 32 pill . Running 24 lto cell batteries and super cap under hood . Running 2 mechman 400 alternators has no voltage drop . Any help with larger amps in a 2007-2014 suburban would be great .
32 pill is a large amplifier for mobile. I was getting a lot of RF to my engine also but I was only running a 2x8 Davemade. I wrapped a lot of my engine wires with ferrite chokes
- saltydog
