Coax question for Base station
Super60
3
#409120
Post by Super60 »
Hey guys,
I have presently a horizontal dipole at my base station and run 50 feet of Jefa Tech 213 U.
I have on order a Procomm Proton pt99 antenna to try out my first vertical antenna ever on my Newbie base station and plan on a switch to pick which antenna is best at any particular time. I will need 75 feet and was considering again using the 213 U but the price is about 100 bucks which is fine but I see 75 feet of RG8X on a popular CB site for 59 bucks. I don't know if I can mention them here or not so I won't. They say it is premium quality and their top of the line bla bla bla fine. I did some research and get confused with all the different brands of USA made or crappy offshore or supposedly good offshore brands, imitations etc. My setup if that matters is modest with a smiled on Galaxy 949 ,RM Italy KL-503 non HD,each with their own power supplies. Is 213U overkill and would the RG8X work just as well at 75 feet?
Most of the cable will be inside the garage if that matters. Any recommendations would be appreciated.
73's and thanks
Donate to CBRT
Bombero
14
Re: Coax question for Base station
#409121
Post by Bombero »
Hey..
213U is great and I’ve used RG8X on a lot of application, but I’ve upgraded over the years and use LMR400 exclusively.
Bombero
Support our fine sponsors!
383 Boogieman
Donate to CBRT
Super60
3
#409124
Post by Super60 »
Thanks for the reply. Would you say then the RG8X wasn't noticeably worse than the better coax you have used?
Donate to CBRT
Bombero
14
#409126
Post by Bombero »
Hey..
RG8X was my ‘go to’ coax.
Modified RCI 2950 getting out about 27 watts.
I’ve talked as far as Norway, Finland, and Germany.
Bombero
383 Boogieman
Donate to CBRT
Super60
3
#409127
Post by Super60 »
Got it thank you
Donate to CBRT
13
#409148
Check out the prices on eBay, ARP, Belden, Columbia, Commscope, these are USA manufacturers but good quality coax is not cheap. Anything over 100ft I use a LMR400 type coax, RG213flex on anything shorter.
Donate to CBRT
Super60
3
#409153
Post by Super60 »
Thanks MD
Donate to CBRT
wa380
Mud-Duck Sr.
Mud-Duck Sr.
4
#409391
Post by wa380 »
I would go the LMR400 as a go to coax I use the RG8X for portable HF station its ok for that.
Jason
VK6KS
Donate to CBRT
Super60
3
#409514
Post by Super60 »
Thanks!
Donate to CBRT
443 Arizona
13
#409541
Post by 443 Arizona »
the thing you want to look at is the amount(percentage) of sheilding, as well as overall quality,
i put up RG8? over 30 years ago and it is still working,
Donate to CBRT
Super60
3
#409543
Post by Super60 »
Thankyou. That is impressive!
Donate to CBRT
wgrebel
#410108
Post by wgrebel »
Super60 wrote: June 22nd, 2022, 9:28 am Hey guys,
73's and t
U are leaving out another choice, it is RG-8 or RG-8/U.. It is larger than 8x but should cost less than 213..
Do a google search for Coax Loss Chart.. Good Luck..
73, W.G.
Donate to CBRT
Super60
3
#410510
Post by Super60 »
Thanks!!
Donate to CBRT
Wencyslaus
Mud-Duck Jr.
Mud-Duck Jr.
#410534
Post by Wencyslaus »
Is the wider the diameter of coax the better for receiving stringer signal strength readings on a CB radio in a base station setup?
Donate to CBRT
wgrebel
#410538
Post by wgrebel »
In general it is yes; the distance between the center conductor
and the outer conductor has less loss, but the materials the coax
is made of has to be factored in.. W.G.
Donate to CBRT
443 Arizona
13
#410552
"ladder line" is another type , :idea: unlike coaxial , that can be used, is cheaper, and can solve some problems, and cause others :shock: :roll: ,there is a bit of science involved and then there is a trick , called a "balen" , which is created by looping the coax several times usually at the base of the antenna. (sounds like you have extra coax) :?: you can also cut it, but be leary of the SWR and wavelength theories.
all this helps with SWR, which is the culprit that effects good signals. :eek: :( :( ;) :-)
Donate to CBRT
Swanman
5
#410649
Post by Swanman »
For HF, 213 is fine but for the price it's overkill, unless you're running at least a KW. Where I work, we used RG8X for runs up to 100' because the difference in performance is not worth the added cost for 213. Also mentioned was good ole RG8, also a good choice if cost is a concern.
Donate to CBRT
Super60
3
#410650
Post by Super60 »
Good advice thanks.
Donate to CBRT
