Galaxy 959 I broke it.
Bballard1983
Super Mud-Duck
Super Mud-Duck
#410061
Post by Bballard1983 »
I attempted a mod I found on defpom on my older final version 959. Followed these directions to the letter and no tx. So I put it back to stock and still no tx. Help plz
RF Output Increase Modification
This modification will allow the DX959 & DX949 to exhibit the RF output and swing of the Galaxy DX-series 10-meter radios. The board was always capable of this type of output; it was simply choked off by the design engineers in order to meet FCC 11-meter specifications.
The first thing you need to do is turn up VR14 which is the AM high power variable. If you?ve already done the modulation improvements, you should be able to dead key about 8-10 watts and swing around 15 watts. 18 watts is probably the best you?ll get (using a peak-reading Bird wattmeter). Now, perform the following modifications:
Remove C218 (3pf) and discard.
Change C216 (470pf) to a 1000pf (100V mylar-type)
Remove C210 (470pf) and discard.
Remove C199 (560pf) and reinstall it in the C210 spot.
Adjust your dead key to around 5 watts. I was able to achieve average peak swing readings of around 35 watts. Depending on the audio input (voice or whistle), I was able to whistle myself to readings of over 40 watts peak! There was a slight decrease in modulation and it seemed as though I was really pushing it. I found that I was able to regain the modulation level by lowering the dead key (using the RF Power control on the radio face) to around 2.5 watts. This netted peak swing readings of just around 28 watts! More than enough given the fact that the modulation was over 95% and crystal clear!
Donate here
This is just about the same
performance that I got from my Galaxy DX66V after performing the 1N4001 diode heavy swing modification. Like I alluded to earlier, this new radio has "the stuff." You just have to work slightly harder to get at
Donate to CBRT
#410071
Back in the day I had done this mod and it worked but never got more than 30w swing. My best guess is you have a solder joint shorted or you fried a diode when doing the mod.
"321, Homeless at the moment, lol"
Donate to CBRT
Bballard1983
Super Mud-Duck
Super Mud-Duck
#410076
Any idea what are to search in for said diode? I’m a pretty handy guy an have just enough knowledge to be dangerous so plz talk to me like I have no idea bc in truth I dont. Also I never considered this but I have a 2sc1969 version not the irf520. And Ty for responding
Donate to CBRT
#410078
It would be in the area of the final, most of the mod is in that area. Also, did you check the caps before replacing them, a lot of imitations out there now a days. If all else fails you could try the dual final mod to bring it back to life.
Donate to CBRT
