CBRT has been
Rotor control bulb
Spiderleggs
Handle: Spiderleggs
Real Name: allen
Antenna: antron
Radio: various
Rotor control bulb
#404724
Post by Spiderleggs »
I have a CDE 45-II control unit that had no bulb when I got it. I looked at the manual but it doesn't give the bulb base number or at least the copy I found online. I acquired a bulb from a local auto shop that fit and was the right voltage but it gets too hot and it began to melt the meter as I missed and left it on too long. Does anyone know the base number of the bulb so I can order one from a large online retailer? I saw some LED bulbs which I expect wouldn't get so hot but don't know if they will fit, though I could probably rig it up to work.
Re: Rotor control bulb
#404728
I think the original bulb is a 24v, so 12v would be twice as bright and three times as hot. If you are planing to use LED's then measure the voltage and use a resistor to drop it to the 12v LED level.
Spiderleggs
Handle: Spiderleggs
Real Name: allen
Antenna: antron
Radio: various
#404733
Thanks Mr. Youngblood. I measured the voltage, came up to 13.65v. I remember seeing some 14v bulbs of different wattage (3.4 and 4.1 I believe) so I may try those.
wa380
Mud-Duck Sr.
Mud-Duck Sr.
Handle: jason
Real Name: jason
Call Sign: vk6mgt
Radio: washington, icom 746 pro
#409393
Post by wa380 »
Use LED's put a series resistor in you will have all the brightness and none of the heat.
Jason
