½ wave dipole antenna
EricExtreme
16
#409330
Post by EricExtreme »
I am erecting a ½ wave dipole. I am curious as to what height off the ground will offer optimum performance? I have a 140ft long dipole for 70cm - 160 meters amateur radio and the optimal height was over 100 feet up in the air between two trees on opposite sides of my property. What would the optimal height be for an 11 meter ½ wave dipole? Thanks!
American Eagle 813 (Æ813)
Galaxy DX959b (radio) - Astatic D104 Silver Eagle (mic)
LMR-600 (coax) - 108 inch whip ball mount (antenna)
Donate to CBRT
295 antenna
5
#409331
Post by 295 antenna »
The way I understand it should atleast 1/2 wave length above ground level
Donate to CBRT
12
#409334
A dipole can be installed at any height, the higher the better for distant, I ran one (inverted V) about 12ft off the ground with good results. The ham antenna uses a balun to compensate for irregularities, never seen one go up to the 70 cm band. Are you going to use a balun ?
"321, NW South Carolina"
Donate to CBRT
443 Arizona
12
#409355
Post by 443 Arizona »
i had amazing results at just 20', had experimented with 4 balun's,
Donate to CBRT
