Hey there!
Have you ever considered supporting an amazing online forum that's like having a subscription to a really good magazine, but without the wait for snail mail? Well, we have a fantastic opportunity for you! Donating to our website forum is just like that exciting subscription, offering you instant access to a wealth of valuable knowledge and engaging discussions.
By contributing to our website forum, you become an integral part of our vibrant community. Your support helps us maintain and improve the platform, ensuring that it remains a hub of information and connection for users like yourself. It's like unlocking a world of possibilities and forging meaningful connections, all at your fingertips.
Imagine the impact you can have by supporting a platform where people come together to share ideas, seek advice, and find support. Your donation helps foster an environment of learning, growth, and collaboration, where individuals from diverse backgrounds can come together and make a difference.
So why wait? Join us on this exciting journey of empowering and connecting individuals through our website forum. Your contribution will play a crucial role in sustaining this invaluable resource for the community.
Thank you for considering this opportunity to support our website forum. Together, we can continue to create a space where ideas thrive, friendships are formed, and knowledge is shared. Let's make a difference together!
Donate here
Cobra 25 low receive
If you need assistance with a radio modification or have any questions, this forum is the perfect place to ask. Feel free to pop in and join the discussion!
smoke blower
11
#409116
Post by smoke blower »
Cobra 25 has very low receive and the audio chip gets very hot I checked a few caps any ideas what it could be I also put in a new audio chip and same thing
Post Merge Complete
Added 1 day 38 minutes 6 seconds after previous.
The radio keys up but modulation is very faint and the receive is real low and audio chip gets so hot you can't touch it. Some help would be greatly appreciated
Donate to CBRT
terryj
10
#409125
Post by terryj »
smoke blower wrote: June 22nd, 2022, 4:54 pm Cobra 25 has very low receive and the audio chip gets very hot I checked a few caps any ideas what it could be I also put in a new audio chip and same thing
Post Merge Complete
Both the modulation and the receive audio are processed by the TA7222P (IC1). If this IC is getting very hot then check the associated components to this IC. Check the caps in the output circuit, C61 could be shorted to ground, but check caps C63, C62, C67 and C168. Check for the correct voltages on IC1.
If you don't have a schematic you can get one from here: [Please login or register to view this link]
Donate to CBRT
smoke blower
11
#409128
I will check those out and see what I find I already checked a few around the audio chip . Thank you for helping I will let you know when I get these checked y
Post Merge Complete
Added 8 hours 15 minutes 58 seconds after previous.
I can't find c62 or c168
Post Merge Complete
Added 15 hours 41 minutes 26 seconds after previous.
I have looked the schematic over and the parts layout and I am having a very hard time finding c62 or c168
Post Merge Complete
Added 9 hours 54 minutes 58 seconds after previous.
I have been over this board serval times I don't see a C72 or C168
Post Merge Complete
Added 5 hours 11 minutes 20 seconds after previous.
Man it would be nice to have someone help me with this . This is why I haven't donated to the forum you just can't get any help it takes weeks before you might get a reply
Donate to CBRT
12
#409149
I don’t know a lot about the 25 models and not sure which one you are working on. Looking at a schematic of a GTL, it looks like C62 is just off pin 6 of the audio chip, like you I couldn’t find C168, I think that is in the 29 models. If the chip is getting extremely hot, that is telling me it is being over volted. My guess is the modulation limiter has been clipped or the transistor has gone bad.
Donate to CBRT
smoke blower
11
#409155
The final transistor was ad I pulled it out and tested it and it was shorted. As of now I put in a new one and the radio will key up but very little audio and the audio chip still gets very hot
Donate to CBRT
terryj
10
#409174
Post by terryj »
If the audio IC is getting very hot that means it is drawing to much current. On the TA7222 pin 1 is the voltage in, it should be at your supply voltage. Pin 4 is your audio input an pin 9 is the audio output, this is connected to the collectors of both TR7 (2SC2078E Final) and TR8 (2SC1957Q Pre-Driver) via the modulation adjust VR5.
Somewhere in the output circuit something has changed enough to load the output and draw down the transmit and receive audio. Check C154 it is in series with R118 and connects to ground.
I think is is a much better schematic: [Please login or register to view this link]
Donate to CBRT
Tinkerjim
#409380
Post by Tinkerjim »
I'd check the rx/tx switching transistor s
There should be 8 volt s on the collector
On one in rx and 0 volts on tx if it is shorted
It's not fully going into rx. Still in tx even unkeyed... These transistor are generally in the right front corner of the pcb.
I'll have to look at schematic to get the tr number..
Donate to CBRT
Tinkerjim
#409381
Post by Tinkerjim »
Tr16 is the switching transistor
Check collector ( center pin)
For proper voltage.
Donate to CBRT
smoke blower
11
#409382
Thank you I appreciate it I will get it checked out and let you know what I find.
Donate to CBRT
