Line X
- BLACKMAGIC
- 15
Line X
I have a 2006 crew cab Chevy running a 2x8. I’m considering doing a line-X coating to the whole truck. Is this going to cause swr and reflect issues? Thanks
Follow @cbradiotalk
- 11
Hmm, this is a interesting question. I don't see where it would be a problem as it will be the same ground plane the existing antenna is using, only covered now by a thick material. I never looked at the ingredients of Line X, is there any metal fiber possible, I believe it is fiberglass. I would watch where it antenna is and not use the Line X coating, keep a good ground.
Follow @cbradiotalk
