LINEAR AMPLIFIER RM KL-805 ANYONE HAVE ANY INFO
- DevilsDen
- Handle: 215 Devils Den
- Real Name: Tony
- Antenna: Siro Vector 4000/Imaxx 2000/Antron 99
- Radio: IC-7300-Ranger 2950-Stryker 655-General Lee
I am thinking about buying one from overseas (France)..Does anybody run one? Any info most appreciated...
73
73
Re: LINEAR AMPLIFIER RM KL-805 ANYONE HAVE ANY INFO
Are you going to use it as a base or in the mobile? All I know about them is what I just searched out on the internet. On the ham forums, they still consider them illegal CB amplifiers. I will say it is biased for SSB operation which most "CB amp's" just have a delay cap.
- DevilsDen
- Real Name: Tony
Will be using as a base amplifier. Mostly on SSB some AM..
It probably would be fine for base use, make sure the PS is more than adequate for continuous use. Don’t volt it, RM amps do well with less than 14V, it is a mosfet amp. SWR will need to be as good as possible as well.
- DevilsDen
- Real Name: Tony
Whats your thought on PS i can hit it with 50 or 100 I have both
Ill be driving it with a ic 7300
Thanks for feed back
The spec says 30A for the top of the scale so either would be fine as long as the continuous amperage on your PS are better than that. IO would also recommend not using the same PS for both radio and the amp together, theory behind it is as the radio transmitting draws amperage and the amp draws, it is possible a voltage drop would cause both to detune.
- DevilsDen
- Real Name: Tony
Ok so my AMP arrived from France in great shape.I ran into a bit of a snag though!
I did not realize that this amp runs on 24 volts not 12.. So now i am looking for power supply and any idea of using it in my car are over!
My mistake…
Maybe i will send back
My mistake…
Wow, didn't catch that in the spec's. Give Megawatt a try,
I believe he is still a sponsor to the forum, he might be able to help. At least you and others that read this will know.
- DevilsDen
- Real Name: Tony
Mega Watts definitely helped me out ..The owner John walked me through the whole process. He went over and above......
I HIGHLY recommend them for your power needs
I should have her running today I will post progress
Glad you got it worked out, hope you plugged the forum as where you found him. You might want to make a post here to get your "post count" started,
As it increases more of the forum becomes available.
- DevilsDen
- Real Name: Tony
Not really sure what you mean??
But i am willing to do my part!
Look at your profile pic, under it is a column of info, one says "post" and yours is still "zero", make a post at the link I gave you and every post you make, or answer someone else's, will start adding up. after 100, you can add pic's to your post, and some other things.
