Not now
Get a better experience by installing our web app!
Hide
How to do it?
In Safari, tap on the menu bar. Scroll down the list of options, then tap Add to Home Screen.(If you don’t see Add to Home Screen, you can add it. Scroll down to the bottom of the list, tap Edit Actions, then tap Add to Home Screen.)
Connect with CB radio enthusiasts at CB Radio Talk Forum. Fuel your knowledge, unlock secrets, and engage in discussions. Join a vibrant community of like-minded individuals and explore the exciting realm of CB radios.
Here's a little add on electret mic tester to work with my mic tester to check electret mic's. it's more compact than the huge mic tester i built and only made to test electret mic's.
The triple pole, double pole switch on the back kill's the electret part of the circuit out so you can check a standard mic, then turn on the electret part to verify it's operation. 73
