Bent ground plane section? W58 Antenna
- Handle: Rick
- Real Name: Rick
- Radio: Galaxy
I was putting up my antenna, a Workman version of the Maco 5/8 base antenna, and I noticed I bent the one piece. Is that an issue in performance? Can it be cut the 3/4" so that it is straight again? Or just leave it?
It's only up temporary until I get the tower actually installed, I was going to try bending it back but being it is bent where it is split to clamp onto the antenna base stud, I'm guessing I may not be 100% successful...
- jessejamesdallas
Re: Bent ground plane section? W58 Antenna
cutting it will mess up the SWR and it may not be able to tune very good...pending on how much you cut off.
- Handle: Rick
- Real Name: Rick
- Radio: Galaxy
But being bent won't really affect it then?jessejamesdallas wrote: ↑March 24th, 2022, 6:11 pm cutting it will mess up the SWR and it may not be able to tune very good...pending on how much you cut off.
- cigar czar
- Handle: CIGAR CZAR
- Real Name: Jason
- Antenna: 102" whip
- Radio: Stryker 497, Galaxy 959, Super Star 3900
Yea leave it be. I have the 5/8 Maco. If you can straighten in later that's fine but I would not worry about it other than looks.
Mobile
1)Galaxy 98VHP, 102" whip
2)Galaxy 959 p5/6 mod
3)Stryker 440hp w/Xforce 200hd
4)Superstar 3900EGHP American Spirit
5)Stryker 497
6)Galaxy 95t
Base
Maco 5/8
I run one of my mobile radios
5)Stryker 497
6)Galaxy 95t
Base
Maco 5/8
- jessejamesdallas
It might if it's bent over like a horse shoe or something, but just a little crooked shouldn't hurt anything.Cutlass327 wrote: ↑March 25th, 2022, 7:03 amBut being bent won't really affect it then?jessejamesdallas wrote: ↑March 24th, 2022, 6:11 pm cutting it will mess up the SWR and it may not be able to tune very good...pending on how much you cut off.
There is a ham radio shop (sorry they aren’t a sponsor so I can’t give a link, PM me for it) that sells aluminum tubing to build homemade antennas. Getting parts for a Maco, contact the manufacturer, they sell the piece you need to replace it.
