Looking for help - more of a repair type question.
I have a Realistic TRC-216 hand-held and I need to remove the front panel from the body so I can get at (and remove) the PC boards inside. The rear cover (which includes the AA-cell battery holder) is easily removed (three screws) but the front cover/face has no visible fasteners.
If you know where I could go for advice on this (or can suggest how to proceed), I'd appreciate any advice.
Thanks!
Need help - remove front panel/cover from TRC-216 hand-held
- wb0gaz
- Handle: None
- Real Name: Dave
- Call Sign: wb0gaz
443 Arizona Verified
- Mod Duck
- Handle: Double R
- Real Name: Steve
- Radio: madison on 5/8 wave
Re: Need help - remove front panel/cover from TRC-216 hand-held
everything comes apart from the back side, in layers. your going to end up with a total teardown .
443 is right, everything is accessed through the back.
