Moonraker 4 Parts
Bigdog3
Handle: Bigdog3
Real Name: John
Radio: Cobra 2000 Kenwood 430s
Moonraker 4 Parts
#400826
Post by Bigdog3 »
Hello all I have a Avanti Moonraker 4 that I need a part for it is the bracket that the coax's attach to the part number is 519.120. I see were others have built antennas with gamma rods and attach the coax to the rod with a solder on loop. Sounds like a better way to go with no connector corrosion issues . Also need the little plastic part that the screw goes through into the gamma rod. Would like to do it with the bracket if I can. I sent **Non Sponsor** an email for it but not expecting anything. Antenna is new Thanks for reading any help would be great
Message from moderator MDY
removed **Non Sponsor**
Lost Ram
Handle: Lost Ram
Real Name: Kerry
Re: Moonraker 4 Parts
#400827
Post by Lost Ram »
Are you talking about the SO-239 that the coax screws too??
CB: TRC-450, Imax
Thomas Jefferson.
Bigdog3
Handle: Bigdog3
Real Name: John
#400828
Post by Bigdog3 »
No actually it is the bracket made of aluminum that the so-239's are attached to and gamma rods attach to
Part number 519.120
#400829
Parts for a discontinued 40+ year old antenna will be hard to come by. I had a friend who had the same problem. I modified the gammas with coax pigtails to make the connections to the feed coaxes, used a thick plastic kitchen cutting board cut down to make spacers for the gamma's to hold them in place and spark plug boots to seal the gammas. His antenna has been up and working for over 5 years with the mods. A little ingenuity goes a long way.
Bigdog3
Handle: Bigdog3
Real Name: John
#400830
Post by Bigdog3 »
Thank You I will probably end up doing that the rest of antenna is new including gamma rods
