Cobra 29 Ltd
drew434
Handle: bandit
Real Name: Drew
Antenna: A 99
Radio: Galaxy 99 v
Cobra 29 Ltd
#386683
Post by drew434 »
I have cobra 29 Ltd I put a channel kit in it and from channel 14 to Channel 1 Is gone thank you
[ Post made via Android ] [ external image ]
Re: Cobra 29 Ltd
#386695
Look at your solder joints at the PLL and make sure you didn't cross any, only other thing it could be is a bad IC in the channel kit. Which kit did you use?
drew434
Handle: bandit
Real Name: Drew
Antenna: A 99
Radio: Galaxy 99 v
Re: Cobra 29 Ltd
#386708
Post by drew434 »
It's a plus kit
Re: Cobra 29 Ltd
#386709
drew434 wrote: August 9th, 2017, 5:08 pm It's a plus kit
I'm guessing here, it's a old Expo "A+" kit?
drew434
Handle: bandit
Real Name: Drew
Antenna: A 99
Radio: Galaxy 99 v
Re: Cobra 29 Ltd
#386711
Post by drew434 »
Yes Expo "A+" kit?
Handle: sonoma
Real Name: sonoma
Radio: President Washington
Re: Cobra 29 Ltd
#386714
Post by sonoma »
did you follow the instructions as written? you need the varactor diode installed if you can not adjust for the channels.if this is a old 29ltd in most cases you have to use the cap and the diode and make the adjustments as listed to get it to dial in.
[ Post made via Linux Laptop ] [ external image ]
drew434
Handle: bandit
Real Name: Drew
Antenna: A 99
Radio: Galaxy 99 v
Re: Cobra 29 Ltd
#386717
Post by drew434 »
Ok thank you
drew434
Handle: bandit
Real Name: Drew
Antenna: A 99
Radio: Galaxy 99 v
Re: Cobra 29 Ltd
#386720
Post by drew434 »
It's a 29 chrome
Handle: sonoma
Real Name: sonoma
Re: Cobra 29 Ltd
#386723
Post by sonoma »
did you install the diode and cap that came in the A+ kit. I have noticed if the radio does not peak properly as you have lost some channels the diode and cap needs to be installed. you did not say if you used them or not in your reply.
did you get the diode and cap with your kit, did you get get the install paper work with your kit. I have noticed some of the kits mention the cap and diode and they were never put in the box to add them. the diode for the kit is a BB329 part number.
