Cobra 29ltd classic antenna light coming on
- phic4538
- Real Name: patrick
Have a cobra 29 ltd classic that when I key up antenna light is coming on. I have checked antenna grounding an everything. Even put a spare radio in the truck to make sure that the setup is good. It just happens with this radio?? Any help would be appreciated!!
- Slyguy
- Real Name: Sly
- Antenna: Yes
- Radio: Kenwood, Yaesu, Icom
Re: Cobra 29ltd classic antenna light coming on
What's the SWR looking like?
Slyguy
Zero Six Three
Sherman Texas
Support our fine sponsors!
Zero Six Three
Sherman Texas
- phic4538
Believe it was around 3 to 4. I replaced coax and antenna aswell to make sure
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
running 3 to 4 swr is why the light is coming on. it is set at the factory for around 3. better get the swr down to 2 or less. the lower the better. I try for 1.5 on my radios or lower.
Hello phic4538,
Welcome to the forum. I hope you aren't depending on the SWR meter in the radio. Get a good external meter and adjust the SWR to less than as close to 1:1 as possible. You never mentioned what antenna you are using.
As a new member could you post an intro in the "Welcome to the Forum" topic, [Please login or register to view this link], so other members can say "Hello", thanks.
After you get the SWR problem with the antenna done a "poor man's" way of adjusting the antenna warning light is to purposely detune the antenna (mark it so tuning it back to 1:1 is easier) to 2:1 on channel 19 or 20 using a reliable SWR meter and adjust VR6 on a Cobra 29LTD so the light just comes on at 2:1.
A 25 or 100 ohm resistor used as a dummy load will simulate a 2:1 swr. There's not a thing wrong with the internal swr meter in that radio. It may not have super accuracy but tune the antenna so the swr is as low as possible and that's the best you can do. It may show 1.5:1 and your external meter may show 1.3:1 but if you've already tuned it as low as possible what else are you going to do?
Most external meters marketed towards cb are pretty crummy. If you want super accuracy buy an antenna analyzer or use a bird meter to measure reflect. If you want to test the accuracy of an swr meter you can do so with an old coax jumper and some resistors. Cut an end off the jumper. And connect the center and shield to a 50 ohm resistor you should see 1.1:1. With a 75 ohm you should see 1.5:1, with a 100 ohm you should see 2:1, with a 150 ohm you should see 3:1. Use 2 watt carbon resistors and only your radio...no amplifier or high power radio unless you have big enough resistors to take the power. Don't stay keyed for too long as the resistors will heat up. Just key long enough to calibrate and get a reading.
- TheCBDoctor
- Sponsor
- Handle: Rick
- Real Name: Rick
- Antenna: Wilson 2000
- Radio: HR 2510
Good morning phic4538,phic4538 wrote:Have a cobra 29 ltd classic that when I key up antenna light is coming on. I have checked antenna grounding an everything. Even put a spare radio in the truck to make sure that the setup is good. It just happens with this radio?? Any help would be appreciated!!
Your radio was "Peaked and Tuned" which means D-11 is cut or VR-4 was adjusted to disable the audio limiter. The SWR meter on the original Cobra 29 LTDs work fine. Well enough to determine if you have problems with your antenna system. You need to readjust the "Idiot light"
The adjustment is the variable potentiometer at the very right rear of the radio (VR-6). Adjust it counter-clockwise until the "Antenna warning indicator" stops coming on. This circuit has no affect on the calibration of the radio's built in SWR meter, which despite what others may believe is fairly accurate in the older models.
The new LX digital series has issues and I would not depend on that radio's SWR meter.
Respectfully
Respectfully as always,
Rick
Rick
- phic4538
Thanks for all the advice!! Planning on tuning the antenna which has never been done on the antenna which is a steel whip 120" I believe is the length on it.. Will post results
- 795
- Antenna: firestick dipole
- Radio: ALINCO/GALAXY
Where is the antenna mounted?
DOCTOR/795
DOCTOR/795
73
795/doctor/ chnl / 36//USB/AM
HAMSPHERE<NO LICENSE REQUIRED>
VOICE OF THE CORNFIELDS
SGT VIETNAM 1967-68/14th ICC
US COAST GUARD 1971-1980
AIR NATL GUARD 123RD COMM 1981-1991/RETIRED
