D104MB6 to Anytone AT-5555 Mic Question...
- psychotron
- Handle: 2ct1206
- Real Name: Jeff
- Antenna: Wilson 1000, Dipole
- Radio: YeticomOptima-AT5555
I have a D104MB6 hand mic wired as a 4 pin cobra. Do I just remove pin 4 from the mic connector to use it on an Anytone AT-5555 or does something special need to be done using this type of microphone on this radio.
TIA!
TIA!
- Night Crawler
Re: D104MB6 to Anytone AT-5555 Mic Question...
After looking at the schematic for that radio it looks like that's all you have to do.
- dirtyjob
- Handle: dirtyjob
- Real Name: Mark
- Antenna: Super Penetrator 500
- Radio: Many
pin 4 is that hot wire that you want to make sure you don't ground out (channel selector)! Pin 3 is the mic audio. Pin 2 looks like it is the push-to-talk switch. Pin 1 is the shield/ground
1- shield/ground
2- transmit "red"
3- audio "white"
4- no connection
1- shield/ground
2- transmit "red"
3- audio "white"
4- no connection
"LISTEN FOR THE PING"
Gizmotchy G-31 Beam
Super Penetrator 500 5/8 Wave
Comet GP9 2 meter/440
CBRT 18204
Gizmotchy G-31 Beam
CBRT 18204
- psychotron
- Handle: 2ct1206
- Real Name: Jeff
Thanks for the help guys. ![Drunk :drunken:](./images/smilies/drunken_smilie1.gif)
It would be a good idea to put a piece of shrink tube on the #4 pin pad in the mic connector just in case one of the other wires breaks loose and comes in contact with it. I know it sounds impossible but better safe than sorry.
