Get a better experience by installing our free app!
Not now
Get a better experience by installing our web app!
Hide
How to do it?
In Safari, tap on the menu bar. Scroll down the list of options, then tap Add to Home Screen.(If you don’t see Add to Home Screen, you can add it. Scroll down to the bottom of the list, tap Edit Actions, then tap Add to Home Screen.)
Connect with CB radio enthusiasts at CB Radio Talk Forum. Fuel your knowledge, unlock secrets, and engage in discussions. Join a vibrant community of like-minded individuals and explore the exciting realm of CB radios.
My swr is the same on ever channel it is about 1.5. i have dual antennas on the mirror and i ran a ground wire from each to the chasey is that a bad thing or does it not matter at all.
with deul antennas thay need to be at least 6 feet apart for them to work corectly, but a 1.5 isnt to bad a deul phaze setup... try a single i bet you you'll do better
HI-TECH wrote:with dual antennas they need to be at least 6 feet apart for them to work correctly, but a 1.5 isn't to bad a duel phaze setup... try a single i bet you you'll do better
I agree with HI-TECH.
Are you using, or considering, a Wilson 2000, Mr. Coily, or Predator 10K?
