Amp on SSB
Whether you're new to using single sideband (SSB) or have years of experience, this forum is the perfect place to ask your questions or provide assistance to those who are new.
otter
Real Name: Rabbit 227
Amp on SSB
#223218
Post by otter »
when i hook up an amp to SSB.
I know that AM has to have a dead key of about 1 or 2 watts.
what should SSB dead key at in order to run am amp on it?
and is a Palomar 600 a good amp for SSB?
linx
Re: Amp on SSB
#223251
Post by linx »
SSB deadkey will be about nothing. When you modulate you produce the wattage.
If your amp has a SSB relay then it will work fine.
SARGE
Handle: SCOTCH
Real Name: Brandon
Antenna: Predator 10K, Wilson 5000
Radio: Mirage 44, Galaxy 88, 99v, GL, Lincoln, RCI 2950
Re: Amp on SSB
#228172
Post by SARGE »
I believe your Palomar 600 is an AB1 amp and has the SSB delay switch. Friend of mine has a Palomar 1000 (2x4, in his mobile) and it sounds great on SSB, as does his Galaxy 77. Had a guy the other day ask him if he was on a base (yes, he is that clear and loud).
TheTeZ
Re: Amp on SSB
#228176
Post by TheTeZ »
just to clarify, their is no dead key on SSB
Circuit Breaker
Handle: Circuit Breaker
Real Name: Stephen
Call Sign: K7CB
Antenna: OCF Dipole
Radio: HR2510/Yaesu FT-950
Re: Amp on SSB
#228239
Post by Circuit Breaker »
Any amp that has a mode switch that says AM/SSB will work fine. As mentioned, the amp won't key up on SSB until you talk because there's no power output until then. The SSB mode on these amps switches in a capacitor that charges up when you first start talking and slowly discharges between words to keep the relay energized so it isn't constantly clicking back and forth which wears it out.
Yaesu FT-950
Yaesu FT-8100
Uniden Washington Base
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
