980ssb Rx/Tx
This forum is for general discussions, and you are welcome to post in this forum if you are not able to find the right place.
184Ontario
980ssb Rx/Tx
#410047
Post by 184Ontario »
Hello everyone. Acquired yet another broken Bearcat 980. When keying up the radio am and ssb, it switches from Rx to Tx normal. But quickly switches back to Rx? Also will not hold a dead key(Am).
When using the talkback I can hear about 1 second of great audio then quickly cuts out. So far replaced every capacitor, new driver and final. The three transistors held on the side of the radio held in place with clamp.
Tried 6 mics, jumped the mic pins with screwdriver. Used volt meter on every test point, transistors everything imaginable. Hp frequency counter shows good frequency. I'm missing something for sure. Leaning toward bad IC/PLL. Not my first rodeo with radios and don't reach out unless INEED HELP. Lets talk
Donate to CBRT
#410051
If I’m not mistaken, that radio has a SWR protection circuit that stops the radio from transmitting, would have to check it out in the menu, also check the diagnostics in the menu too.
3’s
"321, Homeless at the moment, lol"
Donate to CBRT
