Title 95.420 May I connect my CB station transmitter to a te
Locked
Phaze91460
#52001
Post by Phaze91460 »
May I connect my CB station transmitter to a telephone?
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.420]
[Page 532]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
               Subpart D_Citizens Band (CB) Radio Service
Sec. 95.420  (CB Rule 20) May I connect my CB station transmitter to
a telephone?
    (a) You may connect your CB station transmitter to a telephone if
you comply with all of the following:
    (1) You or someone else must be present at your CB station and
must--
    (i) Manually make the connection (the connection must not be made by
remote control);
    (ii) Supervise the operation of the transmitter during the
connection;
    (iii) Listen to each communication during the connection; and
    (iv) Stop all communications if there are operations in violation of
these rules.
    (2) Each communication during the telephone connection must comply
with all of these rules.
    (3) You must obey any restriction that the telephone company places
on the connection of a CB transmitter to a telephone.
    (b) The CB transmitter you connect to a telephone must not be shared
with any other CB station.
    (c) If you connect your CB transmitter to a telephone, you must use
a phone patch device with has been registered with the FCC.
                      Other Things You Need To Know
Locked
