lighting and antennas
"it's science".....and what law of science are you basing your opinion on...the law of lightning and "pickle" jars. I'm convinced that in that nano-second of the strike the "heavy old milk bottle" bought me some time and protection.
Some of the strike may have went out the way of the groung lead I provided. Then there was the energy spent to melt the bottom of the glass. Get you a propane torch, sit there and see how long it takes to melt the thing yourself (not an easy task). All this may have lessened the amount of energy spilling into the shack, and I'll take any available protection I can get.
The fact that I wasn't picking glass up for a long time punches a l'il hole in your supposition.
Look, a lightning hit isn't an exacting science. There are variables all around. Some are killed by the energy given off by a near hit, some people have been hit directly and walked away. Some hits can devestate a house, other hits can't shatter a milk bottle. You can stick to your voodo science, I'll take the added protection that the glass affords.
Pips
Pips
- firefyter
- lonesome 500
"keep your head in the sand".......please get your head out of.....well, I won't go there. Just try to read all parts of the posts and comprehend them. I had stated that I now have a very elaborate ground field and system along with other static discharging methods to defray the possibility of strikes
and to minimize the effects of one if it does occur.
I will take any added protection I can get and if the "pickle" jar (again, please reread and try to get the facts straight) offers in the least any added protection (which I have experienced first hand)
, I will take it.
, I will take it.
- firefyter
Pickle jar, milk jug, whatever......It offers NO protection from a lightning strike. Facts are Factspipsqueek wrote:I will take any added protection I can get and if the "pickle" jar (again, please reread and try to get the facts straight) offers in the least any added protection (which I have experienced first hand)
, I will take it.
- Texas Mobil 219
Two things i found about direct hits of lightning. One a mini van. All it did was damage the antenna.
And two and Airplane In Fight. And didnt come crashing to the ground.
If nothing can take a direct hit. (I know this from my old rig.) Than why did this two out of many make it. Exspecialy the plan. You would think it would come crashing to the ground.
- firefyter
You are comparing apples to oranges.....Airplanes get hit all the time in flight.Texas Mobil 219 wrote:Two things i found about direct hits of lightning. One a mini van. All it did was damage the antenna.
If nothing can take a direct hit. (I know this from my old rig.) Than why did this two out of many make it. Expecialy the plan. You would think it would come crashing to the ground.
A mobile is insulated from the ground(much like an airplane)
A base setup is NOT insulated from the ground and thats why lightning often damages equipment. Strikes are unavoidable but damaged equiptment is not. A properly setup and installed grounding system(Which does NOT include glass jars)will most likely save your radios and such. Your antenna may not be so lucky.
Hey , I was answering TM219's comment. You still continue to be-little my way of doing things. Ya know what .....you don't have to do it if ya don't like it. But don't put down my way of doing things.
You remind me of my brother-in-law....he likes Pepsi so he contends that Coke is no good and that anyone who likes Coke is off their nut.
Go blow your putdown comments out your a--
- firefyter
- lonesome 500
Lightning follows no rules.
You can protect yourself but a direct hit will cook what it makes contact with. A hit 1 mile away will probably cook or damage your equipment. Disconnect your coax. Properly ground your system and antennas. I use ICE lightning arrestors directly grounded to building rod. These even ground the center not just the the shield. Even with those I disconnect coax when not in use. Take no chances, don't skimp on grounding and pray you dont get smoked.
DOMINATOR TYPE AUDIO DRIVE !
STAY TUNED .....
STAY TUNED .....
Franklin!!! Ya gotta be kidding, right? Uhhhh yea, I've heard of him. Patriot, superior statesman, postmaster general, inventor of the 100 dollar bill and avid cb enthusiast. Let's see ya want people to look up what he's accomplished with protecting radio stations from lightning strikes....wow.
Or maybe he did that on the side commercially for a larger venue. It would have to have been one of the older station, WOR, WHN perhaps. What a joke. Yea he did the key thing. Hardly gives him the authority to write the thesis on lightning protection.
While others have offered suggestions and firsthand experience here, all you have done is berate them while spouting jems like "facts is facts, science is science, and lightning is hot".
Go fly a kite.
Go fly a kite.
- firefyter
Sorry I got under your skin. I just don't want people using your logic and putting their coax in a pickle jar it offers NO protection from lightning as you say. I hope by ticking you off that I've made my point and no one else will believe your nonsense. I have tried to help educate you on lightning protection but you refuse. I have not berated you, only told you facts that you refuse to believe. Do some research for yourself
- firefyter
BTW Pipsqueak.....you really need to do some research on subjects you think you know about. You can't possibly be that stupid. Franklin invented probably the most important piece of lightning protection equipment in history. Like I told you several times before. Inform yourself before debating something you have no knowledge in.
Please try and be civil, no sense resorting to name calling. I am an electrician, been in the trade for over 25 years. I have done housewiring, high voltage line work, and now do industrial control cicuitry. I have worked with many good, knowledgable electricians for many years and we never, ever used any kind of glass jars as insulators. This is an old wives tale. Lightning knocks whole trees down, destroys metal, wood, concrete ect.. Why on earth would a glass jar provide any more protection? Do you ever see a glass jar on any of your electrical companys trucks? Unplug the coax and keep those insurance premiums paid!
- lonesome 500
exactly............
but glass was once used in electrical transmission line insulators....ie power poles
this started way back in the DC days of telograph
once it was found to be inefective at higher voltages.....they were changed to a ceramic
not for voltages of lightening
<center>
<a><img></a>
</center>
<a><img></a>
</center>
As stated earlier the jar did help somewhat in a lightning incident I had years ago. This is why I still incorporate it as a last ditch bit of protection with a more elaborate setup(based on guess-who's lightning rod design).What happened, happened. I related the facts. Yea it gets under my skin when I'm basically being called a liar.
Get's worse when the **Censored** calls me stupid in his last post. At least I'm smart enough to read and understand all parts of others' post, and not pick and choose the parts the dumbell wants to make his arguments.
Didn't you see the reference to "guess whos' lightning rod design" when talking about my system. Let me give you a hint there schmekie....uhh ...Franklin.
Please learn to read between the lines. There are none so blind as those who won't see.
I tried to break the tension with a humorous retort ( the $100bill thing, the WOR,WHN thing, the go fly a kite ((a poor Franklin joke)) ) while still trying to make my point.
Apparently it didn't make a difference to your miserable, humorless outlook.
So look you can have the last word after this. I'm sure you'll come back with more shouts of idiot, stupid, unimformed and such. People like you usually do.
If we cross threads on this site please don't engage me with any comments, and I won't with you. I'm done with you.
- Ballixxe
Re: lighting and antennas
Got struck by lightning back in '97...my A-99 looked like a wicker chair that had a stick of dynamite under the seat.
Lost a TV, VCR, garage door opener, and doorbell.
But...
My Uniden Grant was repaired and is still in working order.
I think the only thing that saved the radio was the fact that the freak counter was first in line.
But...
BASE
Cobra 2000 GTL
Galaxy Saturn Turbo (Ranger RCI-2990)
RM Italy 200p
D-104
A-99
4 element cubical quad (coming soon!)
Cobra 2000 GTL
RM Italy 200p
D-104
A-99
