Title 95.423 What must I do if the FCC tells me that my CB s
This is a place to read about the rules and regulations set down by the Federal Communications Commission (FCC) regarding CB Radio.
Locked
Phaze91460
#52005
Post by Phaze91460 »
What must I do if the FCC tells me that my CB station is causing interference?
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.423]
[Page 533]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
               Subpart D_Citizens Band (CB) Radio Service
Sec. 95.423  (CB Rule 23) What must I do if the FCC tells me that my
    (a) If the FCC tells you that your CB station is causing
interference for technical reasons you must follow all instructions in
the official FCC notice. (This notice may require you to have technical
adjustments made to your equipment.)
    (b) You must comply with any restricted hours of CB station
operation which may be included in the official notice.
Locked
