fc390 freq. counter
RBR762
Handle: fisherman
Real Name: ROBERT
Antenna: 102 Whip
Radio: Texas Star TR966
fc390 freq. counter
#389168
Post by RBR762 »
i know this topic has been brought up before but..........has anyone come up with a fix for the problem of the counter reading a couple khz. off after being modded for a Grant XL/148GTL.
I have 3 of them and only one read spot on after soldering JP1 only.............this is board#EPT210014D
Re: fc390 freq. counter
#389171
I thought you had to bridge 2 jumpers on that boardJP1 and JP2 for them to work on a Cobra/Uniden radio. I looked at a board on CB Tricks and it shows a trimmer (VC1) that is used to adjust the frequency.
RBR762
Handle: fisherman
Real Name: ROBERT
Antenna: 102 Whip
#389192
Post by RBR762 »
Tried jumping both and no luck..........the trimmer doesn't have enough range to compensate. Someone on another forum said this is common on these counters and it is a fault built into the microprocessor.
Handle: sonoma
Real Name: sonoma
Radio: President Washington
#389193
Post by sonoma »
this is the only mod I have ever seen for this counter and never used a 210014 board myself. just make sure you jumped the proper pads.
http://www.cbtricks.com/radio ... 10014d.htm
#389194
I've never dealt with one. How close does the variable capacitor get the frequency? Maybe change it to one with more range. I would think the problem would be more on the cheap crystal than the MP since you have one that works fine.
