Mounting Imax 2000
Help with installing an Antenna, or just choosing the right antenna to go with your radio, or your mobile.
battyice
Antenna: iMax 2000
Mounting Imax 2000
Post by battyice » Saturday, 22 April 2017, 5:19 AM
This weekend I plan to get my Imax 2000 setup. I have about 15' of mast that will be anchored in the ground and clamped at the eve of my workshop.
A few questions for you all.
1. What is the best way to store extra coax cable? I will probably have 15' extra of RG-213 to deal with.
2. I was wondering if there would be any problem with installing a small FM stereo antenna on the mast, just below the Imax? I have been wanting to setup an FM antenna for a long time, and it would be very simple to add it to this project - just not sure if it would impact my ability to transmit/receive with the CB antenna. The FM antenna is one of the 20" round units, made of aluminum.
thanks in advance.
Station 731, Northern NY
-Robert
Logged in via: iPhone
Re: Mounting Imax 2000
Post by MDYoungblood » Saturday, 22 April 2017, 11:57 AM
Under the antenna make a RF choke with some of the extra coax, 5 loops about 4 1/2" in diameter (inside the loop), that will use some of it up, the rest can be looped inside anywhere it won't be damaged. The little FM antenna may or may don't cause a problem, best try it and see. Don't put it directly under he antenna by maybe just above the roof peak. Check the SWR before installing the FM antenna and after.
battyice
Antenna: iMax 2000
Post by battyice » Saturday, 22 April 2017, 15:31 PM
Antenna is up. Coax was too stiff to make a choke, I cooked the excess inside. Should have bought a shorter length...Oh well.
SWR is nearly flat. 1.2 to 1.3.
-Robert
battyice
Antenna: iMax 2000
Post by battyice » Saturday, 22 April 2017, 15:47 PM
I meant "coiled" the excess coax inside. Autocorrect on phone got me.
Of course I get the antenna all setup...And nothing but dead air from the CB tonight.
-Robert
battyice
Antenna: iMax 2000
Post by battyice » Sunday, 23 April 2017, 4:03 AM
Here is a picture of the finished product.
-Robert
battyice
Antenna: iMax 2000
Post by battyice » Sunday, 23 April 2017, 4:16 AM
-Robert
Stoneman
Radio: Cobra 2000 GTL
Antenna: Dipole
Post by Stoneman » Monday, 08 May 2017, 18:52 PM
Did ya Ground the antenna, couldn't tell by the pic...
battyice
Antenna: iMax 2000
Post by battyice » Wednesday, 10 May 2017, 2:46 AM
Mast is grounded, but I did not run a ground up to the antenna itself. Are you supposed to ground the mounting bracket of the antenna?
In hindsight I wish I had mounted the antenna on the eve for the main part of the shop. Would have been almost as easy and gotten the base of the antenna up over the rest of the building. Might get a new mast pipe and move it.
Any idea how far a piece of 1.5" galvanized pipe can extend above the eve mount and still handle the wind load of the antenna? I would like to get it as high as possible, but don't want it to fold over in the wind.
-Robert
Stoneman
Antenna: Dipole
Post by Stoneman » Wednesday, 10 May 2017, 18:26 PM
Sure, I would...You can never have enough ground on that antenna... :cheers:
battyice
Antenna: iMax 2000
Post by battyice » Thursday, 11 May 2017, 3:22 AM
Thanks. Any thoughts on the mast pipe? I would love to get the antenna up a little higher.
-Robert
Post by MDYoungblood » Thursday, 11 May 2017, 10:37 AM
Cool pics, especially the Holley double pumper,, lol. A lot of us use chain-link fence top rail as mast because of the swagged end, tight fit and easy to put together. Threaded pipe, the threaded area is a weak point unless you guidewire (guy-wire?) it at the joints. You could watch the local classifieds for a tower, they go over well with the misses. A metal mast going down to the earth (ground) doesn't need a separate electrical ground wire, the metal mast itself is the conductor.
battyice
Antenna: iMax 2000
Post by battyice » Sunday, 16 July 2017, 12:49 PM
Greg, I took the plunge and ordered two 21' lengths of 16 gauge galvanized fence rail. Hope to have the antenna in the clouds in a few weeks.
-Robert
TrblShooter
Antenna: Zerofive colossal
Post by TrblShooter » Monday, 17 July 2017, 7:01 AM
Thats basically how I put my antenna up.. Dug a hole 3 1/2 feet down, 1 1/2 foot wide circle, placed a threaded 10 foot 2" pipe in the center, mixed 11 bags of concrete with rebarb within 3 sections of the concrete, then got another threaded 10 foot 2" pipe, screwed them together, then put a bracket at the eve of my roof, then made a sleeve out of a piece of 3" pipe , welded nuts to the outside of the sleeve , this slides over a reducer that goes from 2" to 1" pipe, then I have a 10 foot 1" pipe into my zero five colossal 5kw antenna.. Right now the bottom of my antenna is about 26 feet off the ground, I am in the process of going up another 10 feet so I can get to the ideal height of 30 feet off the ground. I am going to remove the sleeve and get a 10 foot piece of 1 1/2' pipe and I am going to slide it into the 2" pipe about 3 feet and cross bolt it, then going to take the 10 foot 1" thats connected to the antenna into the 1 1/2" by 2-3 feet then cross bolt that.. Also switching out my coax from rg213 to LMR 600 ultraflex.. Hope thats not to confusing... LOL! :dance: Good luck with your setup.
73's
battyice
Antenna: iMax 2000
Post by battyice » Monday, 17 July 2017, 17:04 PM
What is ideal about 30' off the ground?
-Robert
TrblShooter
Post by TrblShooter » Monday, 17 July 2017, 19:35 PM
I have heard from a bunch of people and read about the sweet spot for vertical ground plane antenna should be at least 30 feet off the ground from the feed point.... So thats why I am raising my antenna another 10 feet..
battyice
Antenna: iMax 2000
Post by battyice » Tuesday, 18 July 2017, 2:47 AM
thanks - I misunderstood you the first time. I thought you meant the base should be exactly 30' off the ground.
11 meters = 36 feet. That is the minimum height I am going for.
-Robert
TrblShooter
Post by TrblShooter » Tuesday, 18 July 2017, 6:39 AM
Its all good, no worries.. Yeah, mine will be around 32-33 feet, and I am good with that... :dance:
73's brother...
battyice
Antenna: iMax 2000
Post by battyice » Wednesday, 19 July 2017, 2:25 AM
When I am finished with the new mast I will be sure to post back with any improvements I've noticed. I've been wondering if having the base of the antenna just over a steel roof does anything...good or bad?
I was talking to a local the other night telling him that I plan to raise the antenna...then I heard "Not sure why you want to go higher, you're pegging the meter in Northern Virginia!".
-Robert
TrblShooter
Post by TrblShooter » Thursday, 20 July 2017, 13:12 PM
The height should definetly help... Anyway, let us know.. :cheers:
narfedwards1
Radio: Browning Golden Eagl
Antenna: Antron 99@25'
Post by narfedwards1 » Tuesday, 25 July 2017, 16:51 PM
The metal roof will act like a giant ground plane ...mite even make it a tad directional.That thing is gonna kick some serious butt...I want one....haha
[ Post made via Mobile Device ] Image
Blue Ox2
Radio: McKinley&Wash&142GTL
Antenna: Patriot 12& DR-Dipol
Name: Mike KPA-223on the IMax2000
Home Phone: Galaxy DX 2517
Cell Phone: 7175724729
Post by Blue Ox2 » Sunday, 30 July 2017, 14:14 PM
Sure thing my friend. What he said. You'll be talkin' with "Georgia 1" and the FL boys.
I'll be listening for ya.
73
Mike
How do you do from Blue Ox2
KPA223
battyice
Antenna: iMax 2000
Post by battyice » Thursday, 10 August 2017, 17:11 PM
Well, I was not able to raise the antenna with the full 36' of mast that I wanted. It got away from me, and I ended up bending about 8' of the pipe. I decided to cut my losses, literally. Cut off the bent section, and stood it up with what was left. Best guess is that there is about 25' of pipe above the ground. The antenna base is now well over the roof , and the tip is over the nearby trees.
-Robert
battyice
Antenna: iMax 2000
Post by battyice » Friday, 11 August 2017, 3:34 AM
It appears that I am "getting out there" pretty good - last night I was able to talk to someone 26 miles away, according to Google Maps. I am quite happy with that. Once I get some skip conditions again we will see how the new setup performs.
-Robert
Post by MDYoungblood » Friday, 11 August 2017, 5:43 AM
Sorry to hear about the mishap, one of the reasons my antennas aren't on the roof, no help. At least your on the air, happy DX'ing.
battyice
Antenna: iMax 2000
Post by battyice » Tuesday, 15 August 2017, 0:04 AM
Forgot to mention in my earlier posts, SWR on my previous setup was 1.2-1.3. Now it is a flat 1.0-1.1 across the channels. Hopped on 38 LSB last night and made contact with someone in Wisconsin, so everything seems to be working well.
-Robert
Blue Ox2
Post by Blue Ox2 » Tuesday, 15 August 2017, 3:12 AM
Thatis great Robert. Sorry about the bent pipebut glad you got itworked out.
Praise the Lord there was not any physical injury.
73,
Mike
KPA223
battyice
Antenna: iMax 2000
Post by battyice » Friday, 18 May 2018, 10:04 AM
After a recent windstorm my antenna has not been working correctly. SWR goes up when it is wet, and when the wind is blowing I get inconsistent performance. Time to take it down and see what is going on.
-Robert
Post by MDYoungblood » Friday, 18 May 2018, 10:13 AM
Chances are one of the 2 joints are loose and possibly the coax is loose or getting moisture in it. The SWR on a fiberglass antenna will go up when wet slightly, more than that there is a problem.
battyice
Antenna: iMax 2000
Post by battyice » Saturday, 19 May 2018, 4:09 AM
Greg, it was loose between two of the sections. Must have been like that for a while, because the threads are now messed up. I know that it was very tight when it went up, so the wind must have worked it loose over time and the storm we had finished it off. I think I can chase the threads and clean things up enough to put it back in service, but I decided to order a different antenna for this application. I ordered a Tram 1498.
Assuming I can get the Imax serviceable again, I will see about installing it at my dads house. He gets a lot less wind, and it would be nice to have him on the air.
-Robert
Bobcat
Post by Bobcat » Tuesday, 12 June 2018, 10:34 AM
THAT is nice!!!
Users browsing this forum: No registered users and 5 guests
